Rs Brake Failure Lamp - BMW Luxury Touring Community
post #1 of 3 Old Sep 13th, 2009, 8:53 am Thread Starter
Lefty's Avatar
Smile Rs Brake Failure Lamp
I have a 04 RS and the brake failure lamp is on. The red triangle lamp is also on. The bike has been sitting for a couple of months and the battery seems a little weak. The brakes feel fine. I rode around the block and the lamp went off but came back on after it sat for about an hour. Any suggustions?
ALL BMW OWNERS SHARE THE SAME QUALITIES, TECHNICAL,SMART AND HELPFUL
Lefty is offline
post #2 of 3 Old Sep 13th, 2009, 9:55 am
Re: Rs Brake Failure Lamp
I have an 04 K1200RS. The only time my brake warning lights came on was for a low fluid level - the dealer had replaced the rear caliper but the tech didn't fill both rear reservoirs properly.
We also have an 04 R1150R that had the flashing warning light problem. Occasionally during a longer ride it would go out and I would think the problem was resolved. However it would be back the next time I went for a ride. A faulty tail light or brake light could produce these symptoms too, but that wasn't the problem for me. Finally I replaced the battery and I have not had the problem since then. I believe the brake systems on both bikes are very similar so the failing battery may be the same issue for you.
2008 K1200LT Biarritz Blue
2004 K1200RS Capri Blue
mccodavj is offline
post #3 of 3 Old Sep 15th, 2009, 11:32 am
rhhall's Avatar
A low battery will cause this to happen, get it completely charged ... a ride around the block won't do it. Ride it for 40 minutes or put it on a battery tender.
rhhall is offline
ABS brake failure warning light shunte3 K1200LT 19 Jul 9th, 2011 6:51 pm
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
flashing brake failure light revisited LoneAmigo K1200LT 4 Oct 30th, 2008 9:08 pm
Spiegler Failure Tallyho K1200LT 26 Oct 21st, 2008 10:05 am
Brake Failure Warning Light rglassma K1200LT 10 Feb 7th, 2006 9:13 am
