K75 Cutting Out - BMW Luxury Touring Community
post #1 of 6 Old Jul 13th, 2009, 4:04 pm Thread Starter
Question K75 Cutting Out
My '92 K75 develops an electrical fault after about 30 mins riding. The headlight flickers on and off, the indicators go erratic (even the cancel switch will operate all four indicators). If I stop the engine and try to restart only the the fuel pump operates (starter won't kick in). The lights won't switch on.
The only way to restart it is to rock it in gear. If I rock it in gear slowly then I can see the headlight coming on and off and only when I have a headlight will the starter engage.
I've checked connections when the problem occurred to no avail. What about the Hall Effect transmitters?
Any other ideas?
jndunne is offline
post #2 of 6 Old Jul 14th, 2009, 8:41 am
Re: K75 Cutting Out
A few guesses:
I don't think the HES will cause the headlight issues so I'd be inclined to think that's not the issue.
Dirty/bad ignition switch?
Failing load shedding relay?
Flying_Duck is offline
post #3 of 6 Old Jul 14th, 2009, 9:42 am
deanwoolsey's Avatar
Re: K75 Cutting Out
Take your battery cables off and make sure they are clean. Many electrical issues are caused by poor grounds. You can also do a quick check with a digital meter by comparing the voltage measured on the battery terminals to the voltage measured on the cable ends at idle. Any differential indicates corrosion in the connections.
deanwoolsey is offline
post #4 of 6 Old Jul 14th, 2009, 10:18 am Thread Starter
Re: K75 Cutting Out
I connected a digital voltmeter today when commuting and readings taken from aux socket were good at btween 13.9V and 14.2V. Even at these voltages indicators were erratic, horn wouldn't work and lights were going on and off.
I will disconnect battery again just to be sure.
jndunne is offline
post #5 of 6 Old Jul 22nd, 2009, 8:48 am
Re: K75 Cutting Out
http://skylands.ibmwr.org/tom/tech/starter.html
Try this.
Ron
beets is offline
post #6 of 6 Old Jul 23rd, 2009, 4:59 pm Thread Starter
Re: K75 Cutting Out
Full marks!!!
Starter moter worn brushes was the problem.
thanks for help and suggestions.
Dublin, Ireland
jndunne is offline
Hesitation, cutting the brown wire question damenke K1200LT 24 Aug 22nd, 2007 3:05 pm
Cutting down windshield beemer100 Bike Talk 11 Mar 30th, 2007 1:53 pm
Speakers cutting out? Morley K1200LT 0 Jan 14th, 2007 2:17 am
tupperware cutting seat lowering kip K1200LT 2 May 9th, 2006 8:23 pm
Cutting Out - Update rdtebeau K1200LT 5 Oct 13th, 2005 5:23 am
