K1200GT 2003 Died on Road - BMW Luxury Touring Community
post #1 of 5 Old Jul 7th, 2009, 12:49 pm Thread Starter
I was riding down the road about 100 mph. Pulled over for a minute or two, started back up, drove 100 to 200 yards and she died. It turns over great. I don't hear the pump noise.
I got it home, voltage 12.6, took tank off spray starter fuel in air ports, starts fine. I bumped the fuel pump directly to battery, spins.... I'm dying here as to why it isn't getting power when I hit the starter button..... Then I tried last night to bump fuel pump again and nothing... is there a float that doesn't allow it to spin unless it has fuel in it???
All else seems fine.
Please guys any help would be much appreciated...
Only put 1250 miles on her, bought it with 40k.
Thanks in advance,
GBR8465
GBR8465 is offline
post #2 of 5 Old Jul 7th, 2009, 9:35 pm
Re: K1200GT 2003 Died on Road
Could be the fuel filter came loose in side the tank. This has happened on many K bikes and produces the same symptoms. There is no float so if the pump does not always run when you feed it with 12 volts direct I would suspect the pump is bad.
post #3 of 5 Old Jul 7th, 2009, 10:33 pm
If fuel pump gets 12v when key turned on, and pump runs, the pump should be ok.
If pump runs a while then stops it could be a bad pump... or a bad / intermittent pump relay... make sure all electrical connections are solid.
Sometimes you can swap relays as a debug tool.
What is your knowledge level on Fuel Injection systems? Have you debugged before?
post #4 of 5 Old Jul 8th, 2009, 12:17 pm Thread Starter
II did remove the fuel pump assy and the darn hoses are all in tack, no cracks...
I put 12 volts to it and nothing, bought a replacement pump(used) off ebay and nothing... I touched the leads together an it sparks or has juice.
Sounds like I have to get a new pump....
GBR8465 is offline
post #5 of 5 Old Jul 8th, 2009, 12:23 pm Thread Starter
Well the pump does not run..... I turn the key on with volt meter in pump sockets and it reads 12 volts for a second, then a click and the voltage drops to 6 or so..... all this with out hitting the start button....
I did switch the pump relay with the hazard relay since they are the same part number, hazards still working... relay good...
Not good, never debugged one yet.... but would like too...
GBR8465 is offline
Road King & 1200RT Contrasted Nodakgus RT Series 15 Jan 2nd, 2007 5:27 pm
Dead Rabbit along the side of the road. norsseman Humor 0 Oct 19th, 2006 9:45 pm
My road trip so far.. sanjaun2 Ride Tales 19 Sep 21st, 2006 2:56 pm
On the road again... CoolDaddy Bike Talk 3 Aug 28th, 2006 11:00 pm
New K1200GT to debut in US at Long Beach IMS eljeffe K1200/1300GT (The Next Generation) 1 Nov 17th, 2005 7:11 pm
