Heat Issues - BMW Luxury Touring Community
post #1 of 12 Old Jun 21st, 2009, 10:51 pm Thread Starter
Heat Issues
I just purchased a 1995 K1100LT which is wonderful. I am very happy except that I found the cockpit to be uncomfortably hot in Louisiana heat in June. From my initial research I see that Baker Air Wings are a popular solution as they bring in more air. However, as well made and superbly engineered as the Beemer is, I find it difficult to believe that this is a common problem that has not received more engineering design attention. Does anyone have a fix or mod that can resolve the issue and not just relieve the excess heat symptoms?
BobK11LT is offline
post #2 of 12 Old Jun 28th, 2009, 9:25 pm Thread Starter
Re: Heat Issues
Well, I guess I have my answer. There is no solution other than the Baker Wind Wings. I have been all over the internet and that seem like the best solution. I apprecaite this site and the great commentary.
BobK11LT is offline
post #3 of 12 Old Jun 28th, 2009, 9:36 pm
ironbuttwannabe's Avatar
Re: Heat Issues
That's a great bike. I had one for a few years. I didn't do anything about the heat, just dealt with it.
Neil '00 K1200LT '08 KLR
"Far away, is far away...
Only if you don't go!!!"
ironbuttwannabe is offline
post #4 of 12 Old Jun 28th, 2009, 9:44 pm
mwnahas's Avatar
Re: Heat Issues
I got a good roasting on my 87 K100 when it got above 80 degrees. My fix was my 03 K1200LT.
Just Go
Cleveland Ohio
mwnahas is offline
post #5 of 12 Old Jun 29th, 2009, 7:21 am
SilverBuffalo's Avatar
Re: Heat Issues
The heat "issue" was actually improved on the K1100LT compared to the K100's
Baker built air wings are the only solution other than "deal with it" or get a K1200LT.
Before you "trash" this superbly engineered bike you should take into consideration that it was built by Germans
a country whose latitude is approximate with our northern states and the Canadian border,
heat is rarely an issue "up there"
I put almost a hundred K on a '96 K1100LT and I think once you get the air wings on the bike
you'll understand why I used to say "I like it more every time I twist the throttle"
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #6 of 12 Old Jun 29th, 2009, 9:52 am
Re: Heat Issues
http://www.k11og.org/forum/viewtopic...215&highlight=
The pictures on the original post got deleted, but on page two there are others.
I used the Reflectix blanket from Home Depot and the replica K Guards on my K75RT and the results were very good.
Ron
beets is offline
post #7 of 12 Old Jun 29th, 2009, 10:52 am
batdriver51's Avatar
Re: Heat Issues
Wanna feel some real heat, get a Harley or a Buell.
batdriver51 is offline
post #8 of 12 Old Jun 30th, 2009, 8:44 pm Thread Starter
Re: Heat Issues
Thanks for your comments. Hearing your comments and the benefit of your experience is appreciated. Helps me know know that I have not missed the obvious. Your thoughts on the K1200 are appreciated. I guess that is where i will go next. But for now it is go K1100!! See you on the road.
BobK11LT is offline
post #9 of 12 Old Jul 1st, 2009, 7:14 am
Re: Heat Issues
Interesting how he covered the whole top of the bike all the way back past the passenger seat, that might work.
I tried a similar approach on my K75RT but only covered the engine (under the gas tank)
and the sides along with those plastic side covers,
the results were that all the hot air was now funneled under the drivers seat
and set my ass on fire (at least that's what it felt like)
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #10 of 12 Old Jul 11th, 2009, 9:07 pm Thread Starter
Re: Heat Issues
Purchased a set of Baker Air Wings and installed them today. (Upper wings only) Wow, what a difference. I rode today in 90 degrees and 90% relativity humidity today and enjoyed the ride. No kidding it was a warm day to ride but the wings did their job and cleared the heat engine. Thanks Baker. Good job!!
BobK11LT is offline
post #11 of 12 Old Jul 15th, 2009, 8:52 pm
Re: Heat Issues
We've been having 100+ degrees in Austin and the heat on the driver(me) tends to be unbearable. However, the K takes it ins stride. Remember, it doesn't get this warm for this long in Germany! Good luck with the wings!
BMWrdr is offline
post #12 of 12 Old Jul 27th, 2009, 5:05 am
jstrasser's Avatar
Re: Heat Issues
Bob,
Several K1100 owners have installed a manual fan switch to keep things cooler.
BMW engineered these bikes to get just about to the red zone on the gauge before turning the fan on (probably emissions related). This allows the engine to build up LOTS of heat.
By having manual control of the cooling fan, I can turn it on as soon as speed slows and the temp gauge now doesn't get past halfway. And the foil mentioned above does help.
Good luck.
'93 K1100RS "Hades"
'07 Kaw 250R (daughter's)
'06 Ducati Monster 620 (son's)
jstrasser is offline
Chasing GT Tech Issues with Broken Processes DavidTaylor K1200/1300GT (The Next Generation) 19 Dec 19th, 2008 5:37 pm
Heat Troller mtrevelino Rider's Gear & Luggage 8 Dec 21st, 2007 11:47 am
Right grip heat out. cfell K1200LT 9 Nov 4th, 2006 8:25 pm
The story of buying my LT (Really REALLY long...) bmwjason Ride Tales 0 Jan 6th, 2006 11:09 pm
