Testing coils? - BMW Luxury Touring Community
post #1 of 6 Old May 31st, 2009, 9:25 pm Thread Starter
Testing coils?
Hey guys new to the forum and new to the K75 world.I recently purchased a 94 k75.The bikes in pretty good shape and just started to have problems with a ruff idle.I searched the
forums but couldn't find an answer so I started this one.I found that when I removed the #3
wire it runs the same.So I thought it could be a wire so I swapped it with the #2 with the same results.I removed the spark plug and connected it to the wire and cranked it and got
spark but not sure if enough.(looks to be the same as the other 2 but not sure)This is what leads me to my question.How do I test the coil? Can I switch the #2 coil with the #3 to see if its not the computer telling that coil not to fire? idk.. Thanks for any advice.
Drod is offline
post #2 of 6 Old Jun 1st, 2009, 10:42 am
SilverBuffalo's Avatar
Re: Testing coils?
This place might have your answers.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #3 of 6 Old Jun 1st, 2009, 11:28 am Thread Starter
Re: Testing coils?
Thanks for the link,Great info but still couldn't find t my answer.
Drod is offline
post #4 of 6 Old Jun 1st, 2009, 12:56 pm
Palerider's Avatar
Re: Testing coils?
Check the compression and read the plug.................?...................
Palerider is offline
post #5 of 6 Old Jun 1st, 2009, 2:06 pm
Re: Testing coils?
I'm not sure how to answer your question, if you're getting spark that would suggest that the coil is working,
I don't have any idea how you would determine if you're getting "enough" spark,
if you've got compression and fuel I would think "any" spark would cause ignition.
I've had a couple of the older K-bikes
put almost a hundred thousand miles on a K75RT
and about the same on a K1100LT,
never had any problems other than fuel related.
The reason I bring that up is if your bikes running rough
I would suggest you look into the fuel filter (it's inside the tank) and the injectors,
they are extremely sensitive to dirt,
My advice is: try the simple stuff first
run some fuel injector cleaner through it, its cheap and easy,
you'll know in about 20-30 miles whether it worked.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #6 of 6 Old Jun 1st, 2009, 11:07 pm Thread Starter
Re: Testing coils?
Well it turned out to be a broken wire inside the connector that goes to the #3 injector.I only found it cause I was checking the connections and pulled the wire out from the plug.It must have been barely making because when I removed the injector before and tested it was working.must have been when I twisted it back to have a look it made contact.I removed the fuel filter and gonna order one tomorrow.Thanks again for the help.
Drod is offline
California SB435 - Smog Testing Motorcycles!! Tom_Becker South West 3 May 25th, 2009 6:15 pm
Mandatory M/C Emission Testing in Nazifornia Lopaca Bike Talk 6 May 24th, 2009 11:10 am
