Brake light on with key out - BMW Luxury Touring Community
post #1 of 5 Old Mar 23rd, 2009, 7:15 pm Thread Starter
anyone ever have a condition where the brake light is on even with the key in my pocket? Only way to turn it off is discnt batt. Can I drive it to the dealer or is it a direct short that could cause additional problems. thanks for the help.
jimt is offline
post #2 of 5 Old Mar 23rd, 2009, 7:57 pm
Re: Brake light on with key out
Drove ole Toad to a BMW shop to pick up the relay that wuz bad, then back home and replaced it later. Only thang about riding while the relay is stuck (if that is your problem) and the light constantly on is - I'm not sure if the brake light brightness is activated with the brake lever/pedal. You might check that before you go, and depending on how far you have to ride. Good luck.
post #3 of 5 Old Mar 23rd, 2009, 8:17 pm
And I believe it is fuse seven on the left hand side that will cut it off when you are off the bike.
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
post #4 of 5 Old Mar 24th, 2009, 7:42 pm
Enjoy The Ride
saddleman's Avatar
I just replaced my brake light relay on my 04 LT this past saturday for the same problem. I'ts located under the fuel tank. It is yellow & part # is 61366902041. I bought one at Advance Auto BWD Automotive part # R3154. I think this is also a Borg Warner Part #. It was just under $8.00. Three days & about 400 miles later and no problems.
The housing was a little different with out the lock tabs but it fit just fine.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #5 of 5 Old Mar 25th, 2009, 8:28 pm
Fuse #1 is switched and provides power ot the brake switches.
Fuse #3 is unswitched and provides power ot the BMU.(Bulb Monitor Unit)
Fuse #7 is switched and provides power to the BMU
Conclusion: Pulling Fuse 3 will probably make the brake light go out when the key is off.
Flying_Duck is offline
No Brake light on trailer jaskjb Trailers, Sidecars, & Trikes 5 Sep 18th, 2008 11:09 pm
Help w/diagnosing cruise light stays on? coug66 K1200LT 7 Sep 17th, 2007 9:05 am
brake light won't shut off Jabrown K1200LT 4 Jun 29th, 2007 10:07 pm
Brake Light Switch jeffklt K1200LT 7 Nov 15th, 2005 2:24 pm
