Common cause for abs warning light? - BMW Luxury Touring Community
post #1 of 3 Old Nov 16th, 2008, 7:47 pm Thread Starter
So I'm just curious, the ABS warning light has been on since I bought the bike.
Is there any common fault that causes the ABS to stop working?
Does it simply need a rebuild, or does the warning come on because of some other reason?
Nick.
Nick_with_a_K75 is offline
post #2 of 3 Old Nov 17th, 2008, 10:14 am
Re: Common cause for abs warning light?
On your K75? One low tech cause for ABS failing the start up check is low battery voltage. The units are real sensitive to a slight drop in voltage from the expected, for a lot more go to:
http://www.ibmwr.org/r-tech/oilheads...on/index.shtml
To find the fault codes, reset procedures, etc., check out the articles under the ABS heading on the IBMWR tech pages.
http://www.ibmwr.org/ktech.shtml
Motor On ,/'
jkersh1 is offline
post #3 of 3 Old Nov 17th, 2008, 1:28 pm Thread Starter
My problem is the ABS warning light next to the low fuel indicator is blinking.
Not both, but just that one. What does that indicate?
How many forum posters does it take to change a light bulb? brianbeemer Humor 24 Mar 26th, 2010 1:46 pm
Final Drive Failure (Warning Light System) Tourdog K1200LT 26 Nov 3rd, 2008 8:02 pm
How many of us does it take to change a light bulb?! Bruce_Yates Humor 4 Mar 1st, 2006 8:03 am
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 12:49 pm
