93 K1100LT ABS1 bleaeding - BMW Luxury Touring Community
post #1 of 4 Old Oct 23rd, 2008, 4:33 pm Thread Starter
93 K1100LT ABS1 bleeding
OK ! here goes LOL
Another buddy of mine has an 93 K1100LT that he rebuilt the rear master on it since it was leaking a little fluid after sitting a little. Well the master was bench bled & installed on the bike & no matter how he tries to bleed the system , it won`t pump up. He tried a mighty vac bleeding tool and some other things but it still has no petal. He read in the factory service manual that if brakes need to be bleed, bring it to the factory service center to have this done. Is there a reason they say that or is the a special tool or something that connects to the ABS computer to open some valves or something.
Thanks.
confish86 is offline
post #2 of 4 Old Oct 23rd, 2008, 6:21 pm
SilverBuffalo's Avatar
Re: 93 K1100LT ABS1 bleaeding
Probably true, go to K11org for more technical info.
My personal experience,
when I bled the brakes I had an ABS fault couldn't reset it.
The dealer hooked up the computer and "cycled" the pump,
fixed it and took all of ten minutes.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #3 of 4 Old Oct 23rd, 2008, 6:54 pm Thread Starter
I was going to join but need a three digit code off the bike & i don`t own a BMW (yet) so it won`t let me join. OH well , i thought it would be a good site but no bike no go.
Thanks for the info , i`ll just ask my stuff here.
post #4 of 4 Old Nov 16th, 2008, 12:17 am
I"m a mod over at K11OG. The secret code at K11OG is "BMW" - it's there to prevent automated spambots from registering and wreaking havoc.
When you register, put something in the hobbies section of your profile (e.g. motorcycle riding) so we can easily tell you're a real person.
One trick for bleeding the rear is to remove either the pegplate or just the master cylinder and point the rear of the master cylinder upwards. Bleed at the ABS modulator first, then the caliper.
Flying_Duck is offline
K1100LT Question JCabranes Other K-Bikes Discussion 20 Apr 26th, 2008 10:26 am
