K100 ideas? - BMW Luxury Touring Community
post #1 of 2 Old Sep 20th, 2008, 6:02 pm Thread Starter
K100 ideas?
To get things started, I am attempting to get an 85 K100 running for a guy at work that let the bike sit for several years. When I got the bike I put in a battery and charged it, turned the key on and verified all of the lights worked, including instrument panel lights. Then I turned the engine over with the starter, it turned over fine. I found the fuel pump locked up and all of the rubber parts in the engine turned to goo. I cleaned that all up and put in new hoses & filter and got the pump working. I drained the fuel rail and hooked it all up. I then tried to start the bike. It turned over fine but no start. I have kept the battery charger on it as I made several attempts to start it and discovered that the pump had quit again, no biggie I'll replace it. Now I go out to see if I can jar the pump into working and the engine won't turn over, just a clicking from the solenoid/relay. AND, the headlight is not working nor are the turn signals. When I hit a turn signal the dash lights both indicators and the on side signal..as long as I hold it. Once I let go all turn indicators and signals go out. What does work is the park lamp, tail lamp and all idiot lights. I've checked each fuse and they are good....ANY Ideas as to what happened?
Morley is offline
post #2 of 2 Old Sep 20th, 2008, 10:02 pm Thread Starter
Re: K100 ideas?
Nev mind. Got it fixed and got it running.
Morley is offline
1985 K100 Tips and Ideas GeneralMilliron Other K-Bikes Discussion 11 Nov 16th, 2008 12:11 am
anyone got ideas for new products? integritynumber1 RT Series 20 Apr 30th, 2008 9:37 am
Ideas for mounting a J&MCB-2003 on the handlebars of a R1100RT pweezer Intercom, CB, & 2-Way Radios 1 Mar 19th, 2007 6:51 am
Any mounting ideas for Autocom/Gerbings leads? emsweeney K1200LT 13 Jan 10th, 2006 7:35 pm
Holiday Gift Ideas RVB1019 K1200LT 6 Nov 2nd, 2005 10:13 pm
