High idle - BMW Luxury Touring Community
post #1 of 5 Old Mar 22nd, 2008, 5:40 pm Thread Starter
moondog's Avatar
High idle
Got the 96 K1100RS back together and started her up. Right off she is idling high, 3k. Disconnected the battery and then connected it again and did the "turn the throttle slowly" with the ignition on. Still high. Disconnecting the battery clears the faults. Still high. I didn't mess with any setting when she was apart. Any ideas ladies and gentlemen?
moondog is offline
post #2 of 5 Old Mar 23rd, 2008, 8:14 pm
OU812's Avatar
Re: High idle
What were the services you performed?
BMW'S ARE THE WORST BIKE IN THE WORLD, CEPT' WHEN YOU COMPARE THEM TO EVERYTHING ELSE!
OU812 is offline
post #3 of 5 Old Mar 24th, 2008, 5:41 am Thread Starter
moondog's Avatar
Re: High idle
Head gasket changed, throttle bodies off (cables not disconnected), most electrical connectors cleaned, instrument cluster assembly off. Basically the whole bike down to the engine to get to the headgasket.
moondog is offline
post #4 of 5 Old Mar 24th, 2008, 8:13 am
grahamw's Avatar
Re: High idle
CHeck your throtle cables. THough you did not disconnect them the outer cable could have snagged at one of the ends - make sure the outer is fitting snugly into its holder.
Regards
Graham Wintersgill
2001 K1200LT
1995 K75RT now deceased
grahamw is offline
post #5 of 5 Old Mar 25th, 2008, 3:55 pm Thread Starter
moondog's Avatar
Re: High idle
Cables ok. Found the TPS way off.
moondog is offline
Hesitancy, surging and high idle .... slparry K1200/1300GT (The Next Generation) 14 Oct 17th, 2007 4:45 am
strange idle behavior louatlvc K1200LT 11 Mar 10th, 2007 2:27 pm
CQ HID High Beam installs.... BillyOmaha Lighting 7 Mar 7th, 2007 12:14 am
HID High Beam on '99 LT dlbushey Lighting 4 Jan 24th, 2007 9:56 pm
HID High Beam on '99 LT dlbushey Lighting 2 Jan 23rd, 2007 1:58 pm
