2005 k1200s tranny drain plug location - BMW Luxury Touring Community
 2Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By jzeiler
post #1 of 5 Old Feb 3rd, 2019, 10:31 am Thread Starter
I just bought a 2005 k1200s with 9500 miles. Going to change fluids and can locate the tranny drain plug. Can anyone here give me a clue on where to locate it at? Thank you.
Homeyg401 is offline
post #2 of 5 Old Feb 6th, 2019, 2:27 pm
jtalka's Avatar
Re: 2005 k1200s tranny drain plug location
Hi,
I have a 2003 K1200GT.. If your 2005 is the same "brick" design as my 03, the tranny drain plug is basically that big hex plug almost directly under the center stand, while the filler is on the right side of the bike/tranny visible with the tupperware on, just above the foot brake pedal.
Joel Talka
Glen Gardner, NJ
2007 K1200LT - Blue
1978 Corvette Pace Car Replica - ZZ383/M22
jtalka is offline
post #3 of 5 Old Feb 6th, 2019, 6:17 pm
bmwcoolk1200's Avatar
The K1200s is not a brick engine like the LT/GT K1200. It has a wet clutch so is the engine oil also doing the transmission on that one?
beech likes this.
Gordon
Sugar Hill, GA
[SIGPIC][/SIGPIC]
bmwcoolk1200 is offline
post #4 of 5 Old Feb 6th, 2019, 10:09 pm
Gordon is correct there is no transmission oil just engine oil that does both jobs. If your bike looks like this.
There is a hose on the side of the oil tank and a dry sump drain under the engine near the headers and of course the oil filer behind the shifter. Be aware that to re-fill the cooling system you will need a vacuum fill device.
bmwcoolk1200 likes this.
jzeiler is online now
post #5 of 5 Old Feb 7th, 2019, 8:26 pm
beech's Avatar
This speaks to the next stage of the problem. You need to use motorcycle oil 5W40 rated 2MA. The 2MA part is to keep your clutch from slipping. You have a neat bike, a real hot rod complete with the nasty idle and hard to ride around town. The final drive will be your next question. Do a search and find out a lot. Only 180ml of gear oil though. If you put your home town in your signature or profile someone near by can help with many details. Lots to read on this forum about your bike also. You can spend hours reading past files.
Beech
beech is offline
Plug Location theoldone RT Series 10 Aug 11th, 2014 4:31 pm
07 FD drain plug Dann323 RT Series 21 Dec 13th, 2013 9:16 pm
Tranny plug fuzz - how much is too much? cws K1200LT 15 Apr 29th, 2013 5:54 pm
Making Custom Cable For Dice sreid iPod/MP3 29 Apr 19th, 2010 10:36 pm
Transmission Drain Plug Size? ajs K1200LT 14 Feb 2nd, 2007 12:59 pm
