rear brake problems? - BMW Luxury Touring Community
post #1 of 1 Old Mar 19th, 2015, 6:32 am Thread Starter
Hi guys,
Over the past few years on my k1200lt 2004 I've had problems with the rear brake (well I think it's the rear brake anyway) what happens is that it seems to come on on its own (with the yellow brake warning light on the dash flashing) enough to slow the bike to a standstill and enough not to be able to set off again unless I switch off at the ignition and switch back on. It tends to happen after using the brake and start to accelerate again.
Has anyone else had this trouble before?
I had it in at the garage a year or so ago with an ex dealership mechanic and he checked it over including abs system and stripped the caliper down etc and it seemed to rectify it for a while before coming back again
Could it be just lack of use? As I've not really been able to put many miles on her over the past few years but it doesn't happen on the front, it's definitely from the rear that slows her down.
Also I'm thinking of taking it off myself and inspecting the caliper. Now with it having the abs unit on, will it leak brake fluid when I disconnect the hose from the caliper?
I ask cos I know it's not just a simple bleed of fluid with going thru the abs unit first, or does it with it having its own fluid reserve for the back brake.
Apologies if this is a bit long winded but I'm trying to think of everything I want to ask
cheers Andy
andy paine is offline
rear brake problems? andy paine K1200LT 9 Mar 20th, 2015 6:56 am
K1200LT Rear Brake Indexing for Rebuild Reference 1jusbill1 K1200LT 4 Mar 5th, 2013 6:50 pm
'04 LT and Squealing Rear Brake...yeah another thread petevandyke K1200LT 10 Nov 3rd, 2007 1:46 pm
Rear brake light not working wjg4 K1200LT 1 Jul 31st, 2006 9:26 pm
BMW Service Bulletin for Rear Brake Squeal Serebigal K1200LT 4 Apr 8th, 2006 9:40 am
