nice scare about 30 minutes ago - BMW Luxury Touring Community
post #1 of 15 Old Dec 25th, 2008, 11:37 pm Thread Starter
Senior Member (ret.)
RaffyK's Avatar
The entire front half and upstairs smoke alarms went off at the same time. Took 4-5 minutes for them to stop on their own.
Looked for signs of smoke etc but could not find any. Weird.
Lessons learned:
1) Grandpa did not react to the noise and check to see what was happening. Will need to go over procedures with him.
2) Youngest was in bed. Did not wake up to the smoke alarm in his room.
There must be a way to shut them off without having to go to the outside panel to shut off all power. They do each have backup battery so don't know how that would play out.
Not carbon monoxide. I'm thinking possible surge?
Phew.
Raffy
RaffyK is offline
post #2 of 15 Old Dec 26th, 2008, 12:43 am
mikerd400's Avatar
Re: nice scare about 30 minutes ago
I'm glad there wasn't a real fire danger. Also, it is very good you observed the problems now, and not during a real emergency.
2005 BMW R1200GS
2003 Kawasaki KLR650
1977 Yamaha RD400
1976 Yamaha RD400
mikerd400 is offline
post #3 of 15 Old Dec 26th, 2008, 1:22 am
dglenn1's Avatar
Happens to us quite frequently. Sometimes it is just dirt and dust building up in the units that causes the false alarm. If it happens again, try to vacuum or blow them out. Good luck.
Dan
2005 K1200LT - Ocean Blue
; Nolan 103 Helmet w/Bluetooth;
and
(Secures gear/luggage);
; Droid X (Replaces
and factory radio);
(Not installed);
(Currently unistalled),
; Clymer Manual; BMW Service DVD
dglenn1 is offline
post #4 of 15 Old Dec 26th, 2008, 2:35 am
Some guy on the Interwebs
LodiHal's Avatar
Yep, dust or dirt fine matter will trigger the smoke detector by blocking the beams. Give them a good cleaning.
Also sounds like a good time for fire drills...
Hal
Lodi, California
If you aren't good for anything else, you can always serve as a bad example.
HDDC Posse
LodiHal is offline
post #5 of 15 Old Dec 26th, 2008, 4:38 am
NOGILLS2's Avatar
Raffy, another thing is alarms may sound because of a sudden temperature climb, because they are upstairs, you may have had a temp change.
Smoke detectors work on two methods, temperature and light refraction, dust, may have caused a false alarm, and the other mentioned above.
Still check out the whole place when it alarms, just to make sure. I was going to suggest changing batteries, but sounds like it has battery backup, you might check them anyway.
NOGILLS2
Booze Brother# 69
2003 K1200LTE "BEERBURNER" RIP 07/21/09
2006 Aluma Trailer "AFTERBURNER" SOLD
2007 ST1300ABS "Quicksilver"
NOGILLS2 is offline
post #6 of 15 Old Dec 26th, 2008, 8:53 am
mtrevelino's Avatar
Another thing is that you should change them every ten years, regardless on how they are powered.
http://www.nfpa.org/itemDetail.asp?c...0safety%20tips
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #7 of 15 Old Dec 26th, 2008, 9:25 am
deanwoolsey's Avatar
Two common but not well-known causes of false alarms are high humidity usually from an unventilated bathroom shower or cooking or a spider (or other bug) inside the sensor unit. The reason you had multiple alarms at once is that 110 volt units are normally installed in parallel so that an alarm triggers all the units.
deanwoolsey is offline
post #8 of 15 Old Dec 26th, 2008, 1:25 pm Thread Starter
RaffyK's Avatar
Thanks all.
I went to the manufacturer's website and read the FAQ. You all hit the nail on the head as far as possible causes.
My take is one of the following:
1) bug/insect
2) high humidity form daughter taking a shower just prior to the alarm going off.
I'll have to verify #2 and see if the timing is correct.
The alarms are interconnected and that's why all of them sounded.
Raffy
RaffyK is offline
post #9 of 15 Old Dec 26th, 2008, 7:40 pm
motorhead's Avatar
Just maybe SPRINKLERS might be better ...... HEY !! it's raining in the house.
That I think may do a better job of getting their attention ?
Glad everyone is OK Raffy ..... Happy Post Christmas and Happy New Year !!
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #10 of 15 Old Dec 26th, 2008, 8:43 pm Thread Starter
RaffyK's Avatar
Changed all the batteriesabout an hour ago. Cleaned all the sensors too.
Scott:
Did your alarm at the store go off on Monday around noon? I saw a Security car parked infront parallel to the curb.
Raffy
RaffyK is offline
post #11 of 15 Old Dec 26th, 2008, 8:45 pm Thread Starter
RaffyK's Avatar
ooops!
Merry Christmas to you, Dawn and the family.
Raffy
Raffy
RaffyK is offline
post #12 of 15 Old Dec 26th, 2008, 9:02 pm
PMitchell's Avatar
Scott,
My daughter and her family live in a relatively new Townhouse in a burb of DC in Northern VA. Local codes require sprinklers.
Wondered if insurance would pay for the damage if they went off for any reason other than a real fire. Only problem is that they are temperature fused and the smoke would probably get them before the water poured down. That part of the code addresses property damage, the smoke alarms are life safety devices.
Raffy,
Glad you found the source. I've set off a couple in hotels when I used to wear suits on business trips and they didn't provide irons in the rooms. Thought the steam would get the wrinkles. Got a couple of calls from the front desk to check on the shower!!!
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is online now
post #13 of 15 Old Dec 26th, 2008, 10:32 pm
motorhead's Avatar
Originally Posted by RaffyK
Scott:
All was well ? .... No clue on why they were hanging around ?
*** Trailer Too ***
T
wisties Required
post #14 of 15 Old Dec 27th, 2008, 12:47 am Thread Starter
RaffyK's Avatar
Seemed to be. i went by again on my return to downtown and the car was gone. just found it odd the way they had parked taking two+ spaces by being parallel to the cur and 3-4' away rather than in the marked spots.
Raffy
RaffyK is offline
post #15 of 15 Old Dec 31st, 2008, 2:17 pm
EXACTLY---happened to us just 2 weeks ago. They kept going off intermittently and finally I call the local fire station (non-emergency #). They said the same thing. I check the face of the alarm and it said, "Replace by 2005". The house was built in 1994. Apparently the small amount of uranium, or whatever that detects the smoke, heat, etc. wears out. Only cost $55 to replace all three. Silence again.
copilot is offline
Another nice ride tale SilverBuffalo Ride Tales 0 Feb 11th, 2007 5:14 pm
Need a sugestion of a nice restaurant strsout South West 7 Jan 15th, 2007 12:34 pm
Nice Feature Added to Site jpalamaro K1200LT 3 Nov 29th, 2005 8:19 pm
Nice Vendor x2 drmajor K1200LT 1 Oct 9th, 2005 8:43 pm
