Starter Problem - BMW Luxury Touring Community
post #1 of 5 Old Mar 21st, 2008, 4:44 pm Thread Starter
Dogg209's Avatar
Starter Problem
I think I have a starter problem but am not sure if its the relay or the starter itself. Sypmtoms began when electrical work was done on the bike (installing power patch for farkles). I used a keyed source i.e. tailights, to make the connection. After getting it back together again I try to start it and it does it start but it sounds like the starter didn't disengage immediately and took a few seconds. This happened 3 times. On the fourth start the battery went dead. Any ideas on where I can start. I began a 10 vacation today and it would be a shame if I cant at least get a little ride in..........
Thanks for your help,
Mark
Mark C.
Lodi, CA
'01 R1100RT
"Not all who wander are lost"
Dogg209 is offline
post #2 of 5 Old Mar 21st, 2008, 6:14 pm
nelson61's Avatar
Re: Starter Problem
Wish I could help you Mark ...but you may want and try the main forum....more views and maybe a faster answer.
Nelson
99 K1200LT
nelson61 is offline
post #3 of 5 Old Mar 21st, 2008, 6:16 pm
dougholck's Avatar
Re: Starter Problem
This is a typical LT thing, when battery gets weak and you try to start it, starter relay sticks on.
Not sure about RT, but this is a maybe fix on the LT:
Disconnect and charge up the battery (probably got weak while doing your farkles).
If starter sticks on when you reattach the cables, tap the starter button hoping it unsticks, if not replace relay.
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
post #4 of 5 Old Mar 21st, 2008, 6:23 pm
nelson61's Avatar
Re: Starter Problem
I just did what Doug said...last week tried to start bike and it was no go. charged up the battery and when I tried to hook up the cables back on it was arc time and starter just started on its own. put on my glasses..gloves turned on the key touched the cables again and bike started then i hit the start button...all good.
Nelson
99 K1200LT
nelson61 is offline
post #5 of 5 Old Mar 21st, 2008, 9:47 pm Thread Starter
Dogg209's Avatar
Re: Starter Problem
thanks very much Doug and Nelson....I knew there had to be an easy answer for this since I wasnt having starter problems before I started messing with the electrical system. Its on the charger now so we'll if I need a new relay. Thanks again.
Mark C.
Lodi, CA
'01 R1100RT
Dogg209 is offline
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 10:37 pm
Computer Problem Response Form Lonewuff Humor 3 Mar 14th, 2008 3:53 pm
Starter Problem Clif K1200LT 17 May 13th, 2007 9:44 pm
Starter problem dcravens K1200LT 6 Jan 2nd, 2007 1:23 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
