Battery Advice - BMW Luxury Touring Community
post #1 of 9 Old Nov 24th, 2007, 6:24 pm Thread Starter
Dogg209's Avatar
Battery Advice
I needed to replace my battery this weekend so I went to Cycle Spec to get a new one. Since the old one was under the year warranty they gave me a new one. I promptly installed and nothing. I ran a meter across the poles and it did not register. Am I missing something here? Please advise.
Mark C.
Lodi, CA
'01 R1100RT
"Not all who wander are lost"
Dogg209 is offline
post #2 of 9 Old Nov 24th, 2007, 8:00 pm
dougholck's Avatar
Thumbs up
Oddyssey PC680
Got one in LT and the GS. If you need one bad, you could borrow one.
Battery Plus in Stockton may have them, or order on line.
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
post #3 of 9 Old Nov 24th, 2007, 8:17 pm
cccpastorjack's Avatar
Verify that your voltmeter is reading correctly on another battery (car, mower, etc). Then disconnect the battery from the bike completely and then check it again for a voltage reading. If you have no measurable voltage on the battery, it is bad.
If you get a reading (over 12v), then re-install it, making sure all terminals, connectors etc are incredibly clean and tight. Then see if bike will start.
If reading on battery alone is below 13 or 12 volts, you probably want to charge it some before installation. Hope this helps!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #4 of 9 Old Nov 25th, 2007, 9:51 am
kapod2t's Avatar
Did you charge it and I don't mean use a credit card for all you wise a**s out there?
Ride fast. Take chances.
2008 K1200GT
2004 Harley Road Glide "Kapo"
kapod2t is offline
post #5 of 9 Old Nov 25th, 2007, 8:47 pm
MattKas's Avatar
Get a jump from a car then see if the battery charges OK after a trip.
Matt Kas
"Riding Year around"
MattKas is offline
post #6 of 9 Old Nov 26th, 2007, 8:15 pm Thread Starter
Dogg209's Avatar
Thanks for all your help guys. I inspected the battery after some discussion with friends and found that the battery was bone dry because battery acid was not added nor was it charged. After putting in some battery acid and charging at 2amps it appears to be good. I haven't started the bike yet but everything comes on. Hopefully I can get this mess back together (had to remove fuel tank) soon and get back on the road. Thanks again guys!
Mark C.
Lodi, CA
'01 R1100RT
Dogg209 is offline
post #7 of 9 Old Nov 26th, 2007, 11:39 pm
strsout's Avatar
Mark, did you had to remove the fuel tank because the battery?
what takes?
Let it charge for a day on a 2Amp charger, just to be on the safe side
Loma Linda - CA
IBA#14,458 - AMA
strsout is offline
post #8 of 9 Old Nov 27th, 2007, 12:20 am
Replace the battery! Once a wet lead acid battery has run part of the plates dry, it is severely limited in capability, and life.
When the water evaporates out, the sulfuric acid is left and the concentration is MUCH higher, the plates cannot withstand the higher acid concentration, so the top of the plates suffered from drying out (re-wetting does not fully fix that), and the bottom of the plates is damaged by the high acid concentration.
post #9 of 9 Old Nov 27th, 2007, 8:30 am
Dan-A's Avatar
This would not be true on a brand new battery that had never been filled with acid.
Dan-A
-----> BMW MOA # 137114
HDDC
2013 R1200GS LC
2009 HD XR1200 Sportster
Dan-A is offline
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
Battery Advice Needed BeemerBob Batteries, Chargers, & Electrical 8 Dec 27th, 2005 3:05 am
