Another mini tech session 3/24/2007 - BMW Luxury Touring Community
post #1 of 10 Old Mar 20th, 2007, 10:07 pm Thread Starter
Senior Member (ret.)
RaffyK's Avatar
There will be a mini tech session at my place this Saturday. Patty and the kids are away for the weekend.
I figure we start at 10 am. Allows us to have breakfast with RCB, then a short visit to A&S and back to my place.
There will be no minor or major services done since we won't have time for them.
As far as I know, the following is on the plate
Alvaro - Valentine 1 and Soundgate install
Roger - Valentine 1 and Baehr Verso XL install
Hal - Lights , fuse block and Baehr Solo install
Doug - Baehr Verso XL install - if he has no honey dos
Raffy - Lights, fuse block and Baehr Verso XL install
There is enough room for all the above bikes. Two in the garage, two under the carport and one outside under a pop up tent if necessary.
Bring your tools. Spectators welcome. Just let me know so i can have enough refreshments etc.
Raffy
RaffyK is offline
post #2 of 10 Old Mar 20th, 2007, 11:13 pm
dougholck's Avatar
Free lunch at Motowheels Open House Saturday ????http://www.ducati.ms/forums/showthread.php?t=19074
Do not know if I will make RCB breakfast?
See you at the Carport.
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
post #3 of 10 Old Mar 21st, 2007, 1:09 am
Some guy on the Interwebs
LodiHal's Avatar
Thanks Raffy! Carport at ten it is!
Hal
Lodi, California
If you aren't good for anything else, you can always serve as a bad example.
HDDC Posse
LodiHal is offline
post #4 of 10 Old Mar 25th, 2007, 1:06 am
BMW Guru
Ted Shred's Avatar
Well.........how did it go today??
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #5 of 10 Old Mar 25th, 2007, 1:42 am
dougholck's Avatar
Thumbs up
Hal had a moment with a gas line fitting that created steam but no explosion!! HID install.
Roger kept threating to throw-up ???? Radar/tunes/com.
Alvaro replaced damaged wing tips and worked on tunes (What happened to my allen wrenches???).
John quitely worked on his LT in the background on GPS, I think.
Jim stopped in for ride to / hot dog at Motowheels for lunch.
I (Raffy) routed lines for Baher com on my GS.
J Flowers came by to pull group back together and worked/advised on most all of the projects (thanks John).
Raffy helped all and got zero of his own stuff done but did get to ride his Duc with myself, Jim and John to Motowheels for lunch and fashion show.
Great day that went by tooooo fast.
Doug Holck
Lodi, Ca
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
BMW MOA 109760
HDDC POSSE
post #6 of 10 Old Mar 25th, 2007, 1:54 am Thread Starter
RaffyK's Avatar
Thanks everyone. Specially for the Pizza.
Here is what I did after you guys left. First I moved the truck back to its normal spot. Then I went inside and opened a bottle of beer (Newcastle). Went back in the garage and pulled up a chair and set my feet on the gS crash bar. Petted the dogs and finished the beer. Had a cold slice of pizza.
Turned on the radio in the garage. Installed the fuse block
and then wired up the Micro DE HIDs. Cut the end of one of the extra
Motolight switches that I had and ran a wire from the relay to one wire
of the switch and from the parking lamp to the other wire on the switch.
The Micro DE HIDs are slaved to the parking lamp. The switch allows me
to run the Micro DE HIDs either with low beam or with low beam and high
beam.
Walked back in the house at 9:15 pm and had an iced tea.
PS: Doug, it's a lot easier to pull the parking lamp light with the headlight housing loose. You will need a piggy back connector female to two male. No need for scotch locks or splices.
Raffy
RaffyK is offline
post #7 of 10 Old Mar 25th, 2007, 2:20 am
LodiHal's Avatar
Raffy,
Thanks for hosting us today. I got my Hella FF50 lamps and my Garmin 2610 installed. If I didn't have to leave early to make it home for dinner with friends tonight I would have gotten the fuse block, Beahr comm, and Gerbings installed also. Oh well, no biggie, those I can handle.
And yes, plenty of gas flows when you manage to snap a quick disconnect fitting in two... Doug, I appreciate your looking for a lighter to help me find the gas leak.
Roger, thanks for splitting the pizzas cost.
John F, again, thanks for all your help!
Still a fun day.
Hal
Lodi, California
HDDC Posse
LodiHal is offline
post #8 of 10 Old Mar 25th, 2007, 3:16 pm
amarider's Avatar
Thanks for the Pizza guys!
After a long morning at A&S specing out my front wheel and rotors, they replaced the rotors. A&S went out of there way under warrenty to try and fix this rotor problem, this is the second replacement set for me is 16,000 miles. Jeff H even lent me his Mustang to go get my new Anakees since they had the Rims off anyway.
Anyway the shuddering brakes are smooth again and I have new rubber. - Thanks to the Great Service Department at A&S!
Finally made it to Raffy's at 1:30 PM and helped eat the Pizza and did as little help as I could get away with on the bikes. Electrical work is very frustrating!
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #9 of 10 Old Mar 26th, 2007, 3:00 am
RdcrzR's Avatar
Thanks from me, too. I hard wired in my 2730 through the map light, and was able to provide some words of wisdom to the guys that were actually there to get some upgrades done. Almost got lost trying to drive 15 minutes for a free hot dog, when all I had to do was simply stay at Raffy's and pitch in for the pizza. Oh well. Was a good day for the weather, and to check out the new Garmin in other than commute traffic.
Good to see ya'll and get in your way!
John Richardson
--keeper of "The Beast"
2k Champagne LTC
Salem, OR.
RdcrzR is offline
post #10 of 10 Old Mar 26th, 2007, 11:30 am
Dan-A's Avatar
Sorry I missed this. After breakfast and a brief trip to A & S, it was off to the office for a few hours of administrivia.
Trade show week in Vegas this week so Wed dinner is out too.
See you guys next week I hope!
Dan-A
-----> BMW MOA # 137114
HDDC
2013 R1200GS LC
2009 HD XR1200 Sportster
Dan-A is offline
Mini Tech Session East Bay Mar. 10th. brasters Northern California 19 Mar 11th, 2007 9:54 pm
Write up on Jeff's tech session In Austin zimbazi South Central 5 Sep 22nd, 2006 8:18 am
Mini Tech Session Saturday 6-24 amarider Northern California 13 Jun 25th, 2006 1:37 pm
Mini Tech Session OKC JPSpen South Central 4 Jun 6th, 2006 4:53 pm
Mini Tech Session... Ted Shred Northern California 13 Nov 26th, 2005 6:18 pm
