Where do I get a battery in Oregon - BMW Luxury Touring Community
post #1 of 11 Old May 6th, 2006, 8:20 pm Thread Starter
SilverBuffalo's Avatar
The last 3-4 mornings I've been getting an ABS fault when I start the bike, after she runs for a while, I restart her and it clears the fault, this morning it took a little longer than yesterday.
I've been around BMW's long enough to know what's happening, my battery is getting weak, it's time, the bike is an 02 with the original battery, getting a new one will be at the top of my to do list come Monday morning. I'm currently in Grants Pass and heading north.
Would appreciate some input.
Thank you
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #2 of 11 Old May 6th, 2006, 8:47 pm
tsBMWminer's Avatar
Battery
http://www.portlandmotorcycle.com/directions.cfm
Hans
The local dealer will have the stock battery in stock. I do not think they have the Oddessy 680 (My choice)
Hope this helps you.
Tim In Portland
2000 Lt Icon
"Ike"
tsBMWminer is offline
post #3 of 11 Old May 6th, 2006, 11:04 pm
avonfloater's Avatar
Cool
There is a BMW dealer in/aroound Eugene, OR. You might try them.
avonfloater is offline
post #4 of 11 Old May 7th, 2006, 12:07 am Thread Starter
Tim
Thanks for the directions, I'll probably call the Dealer Monday am.
I have heard others talking about the Oddesy battery is this something that can be purchased locally or is it strictly a mail order item?
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #5 of 11 Old May 7th, 2006, 2:57 am
patrick2000's Avatar
Thank you
If you run into trouble in southern Oregon Hansens is near Medford (Phoenix) about 30 miles south on interstate 5
http://www.hansensmc.com/
Assuming you are headed north on the I-5 the next BMW dealer (North) from where you are at is in Eugene Oregon a little ways off the I- 5 . The approximate distance from Grants Pass to Eugene is 160 miles
http://www.bmwor.com/
About 55 miles north of Eugene on the I-5 you will find Salem Honda BMW.
http://www.salemhonda.com/
If you run into trouble on the way do not hesitate to contact me, as I check my email constantly and may be able to help out. I will be heavily engaged on Monday, but I know a few brand X dealerships along the way that would be able to help in a pinch.
Hope this helps,
Patrick Fitzharris,
Eugene Oregon.
Pfitzhar(at)uoregon.edu
patrick2000 is offline
post #6 of 11 Old May 7th, 2006, 7:56 am
Hans,
Before you replace the battery, check the fluid levels in the rear brake reservoir. A small drop in fluid due to normal brake pad wear will give you the same ABS symptoms as a weak battery.
Check this thread for more info and pics of the reservoir.
And if you still have the warning light flashing with both reservoirs up at the Max level, then replace the battery.
post #7 of 11 Old May 7th, 2006, 9:39 am
STARFIGHTER's Avatar
Hansons in Medford
BMWOR in Eugene
Don't call on Monday, they're closed.
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #8 of 11 Old May 7th, 2006, 9:22 pm Thread Starter
Thanks for the "heads up"
I checked the rear brake fluid level and its closer to the min than max mark.
My rear pads had to have worn some after all the mountain goat trails I've been on in the last couple of weeks.
I had an issue with a grinding noise coming from the rear, it turned out to be that the pads are a little taller than the rotor and wearing down to an "L" shape with the "hook" riding on the top of the rotor until they fully retract. Last week I pulled the pads and knocked the "lip" of the pads with a screwdriver in a motel parking lot, they still had plenty of meat then, I'll check them again before I buy a battery.
Maybe I should rename this thread: where do I get some dot4 in Oregon
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #9 of 11 Old May 7th, 2006, 10:14 pm
tsBMWminer's Avatar
Autozone
Tim In Portland
2000 Lt Icon
"Ike"
post #10 of 11 Old May 8th, 2006, 1:51 am
That's probably it then. The reservoirs have to be pretty much all the way at the Max mark or you'll get the flashing lights. If they're completely full with new pads, they'll start to flash as the pads get close to their wear limits. If they weren't completely full when the pads were new, you'll definitely get the flashing lights long before you need to replace the pads.
Either way, a bottle of DOT4 is cheaper than a battery so it's worth trying that first.
Note this applies to the '02-'04 bikes with Integral ABS. The '99-'01 bikes have a single rear reservoir without the brake fluid level sensor, and the '05-'06 bikes moved back to a single rear reservoir.
BTW Hans, you've recently been cruising through my neck of the woods and I've been enjoying your ride reports.
post #11 of 11 Old May 8th, 2006, 10:03 am Thread Starter
Appreciate the advice Ken, glad your enjoying my trip reports.
Patrick, thanks for the links you saved me some time and effort, seems the dealers are all closed on Monday.
That will give me today to add brake fluid and evaluate my situation
thanks for the input.
Tim, Denny and Allen.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
Dog-Gone battery charger question! Yuck! wardenross K1200LT 17 Oct 24th, 2006 1:31 pm
Battery Charger bugged Batteries, Chargers, & Electrical 4 Dec 11th, 2005 9:55 am
