Bleeding/Flushing fluid in EHCS on 05+ LT's - BMW Luxury Touring Community
post #1 of 3 Old Apr 26th, 2011, 3:14 am Thread Starter
Smile Bleeding/Flushing fluid in EHCS on 05+ LT's
Is there anyone else in the Northwest in addition to me who has performed this maintenance? BMW has declared this unit as non-serviceable.
Dialogue with a given dealer or via contact with BMW's 800 number for customer service will yield nothing...they just send you to one or the other!!!!!!!
Some of you may have noticed the article/photos of Ari 'the farkle freak' Ignatius and the article by Joe Gottberg as well as comments by John Zeiler and others on the LT forum. I saved the OEM fluid from the initial drain. Subsequent bleeding/flushing a number of times 'cleaned up' visual condition of the hydraulic jack fluid used. There is considerable solids which have settled out from the fluid from my unit. I did not disassemble the actuator but simply bled/flushed it numerous times. I realize this did not get 100% of the crud from the unit. Next winter/spring I will disassemble, etc., following the general procedure of Joe Gottberg.
Based on the condition of the fluid drained from my 05 LT's EHCS, I will likely perform the removal, disassemble, drain/bleed/flush on an annual basis. There is also a need to pull the DC electric motor apart and clean out all the worn brushes residue, lube the bushing end of the rotor and re-lube the motor spline/pump gear.
I have purchased a spare DC motor, replacement brushes sets and o-rings/seal. The design of the brushes on the OEM motor are not exactly the same as the brushes on the replacement motor...the small, braided lead is attached at different positions on the brushes...I have not attempted to explore the possibility of interchangeability to date.
Chicago BMW stated that replacement of the EHCS is only $1100+ or so.
The rep at Marzocchi USA informed me the pump is not available for purchase due to what he has determined as a proprietory agreement b/w BMW and Marzocchi of Italy.
The small DC motor is another matter since it has been used as a starter motor on small Japanese motor scooters/MC's. It costs only $50, including shipping and replacement brushes sets are an additional $9.95/set.
Removal of the EHCS is relatively simple since the frame does not need to be removed. Remove the skid plate, unplug the electrical connection at the lower right, hold a 9mm open end on the flat of the extended ram(EHCS in up position, please), remove the 13mm nut, remove the 8mm socket bolt at the front of the unit(accessed from the left),and slide the motor/actuator down and fwd. NOTE: For the 8mm bolt, use a 90 degree hex wrench with vise grip on the short leg. Comments from any NW owners of 05+ LT's are appreciated. This situation is of special interest to all who wish to keep their LT's instead of opting for the new 1600GTL.
Terry J Thorpe
TSQUARED is offline
post #2 of 3 Old Apr 27th, 2011, 2:24 am
ErnieA's Avatar
Re: Bleeding/Flushing fluid in EHCS on 05+ LT's
Terry J Thorpe
Yes... I just did one in the past month. It is not hard to do. Perhaps we can do a Tech Session for someone this riding season.
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #3 of 3 Old Apr 27th, 2011, 3:15 am
I flush regularly =)
J.M.J...
Dcn Channing
Speed Bleeders and DOT 5 atrovarious K1200LT 11 Jun 24th, 2010 10:27 pm
Just did an easier tranny fluid change PrimePower K1200LT 21 Jul 27th, 2009 11:02 pm
Never again eeejaay1 K1200LT 70 Aug 26th, 2008 10:23 pm
Front brake fluid and Will Be Selling the bike Jabrown K1200LT 11 Oct 22nd, 2007 2:07 pm
Does Old Brake Fluid Smell? Jerrod Maguire K1200LT 7 Dec 13th, 2005 3:00 pm
