Cutaway socket? - BMW Luxury Touring Community
post #1 of 4 Old May 21st, 2010, 12:48 am Thread Starter
wa1200lt's Avatar
Cutaway socket?
Does anyone in the Portland metro area have the cutaway socket used to remove/replace the pivot arm nuts during the weep hole drilling procedure who would be willing to lend it to me for a couple days? (Has anyone ever seen a longer run-on question?)
I have the next 6 days off work and thought this would be an excellent little project. I would be glad to pick it up and deliver it back to you at your convenience.
Thanks in advance,
Loren
WAK1200LT
Loren
wa1200lt is offline
post #2 of 4 Old May 21st, 2010, 1:22 am
AlaskaFish's Avatar
Wink Re: Cutaway socket?
Yes. Actually there are two of us in the Portland area with the cutaway 30 mm sockets! Ernie A and myself to be exact. I'll go ahead and toss mine (which Ernie machined for us by the way!) along with the 12 mm Allen wrench in my backpack tonight and have it at work tomorrow Loren. If you want to give us a phone # via PM or e-mail we can give you a call sometime tomorrow and arrange a meeting for the hand-off.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #3 of 4 Old May 22nd, 2010, 10:09 am
avonfloater's Avatar
Arrow Re: Cutaway socket?
Now that would be a good tech session, Loren. Any interest in extra hands or opportunities to watch?
Denny
Ridgefield, WA
Thanks in advance,
Loren
avonfloater is offline
post #4 of 4 Old May 23rd, 2010, 11:02 am Thread Starter
wa1200lt's Avatar
Re: Cutaway socket?
I wish I had seen your post before I started the job. It turned out to be a fairly easy with the help of the video and the written process. It took about 3-4 hours but the next one would definitely go faster. I would be glad to host a tech session one of these weekends for this or other projects. I have a 3 car garage (I could free up 2 bays) a/c for the warmer days, heat from the dryer vent pipe for those coldest days and good florescent lighting for the dark days/evenings. I also have a m/c lift, Traeger grill, garage refrigerator etc. All the creature comforts!
I would be interested in helping with a 12 K service but would like to have an experienced hand available for the valve clearance check/adjust the first time.
During a good long day we should be able to:
Fluids change
Crankcase oil/filter
Gearbox & Final Drive fluid change
Radiator fluid
Clean/lube shifter mechanism
Change air/fuel filters
Drill weep hole
Replace quick disconnects
Other projects of note might be:
Wire and install additional lights (fog/driving)
Install led lighting for the wind deflectors (I really like this mod)
Install HID lighting
Change instrument cluster lamps (change color, LED's etc.)
Modify speedometer to correct for speed error
Check pre-load on final drive
There seems to be plenty of expertise in the PDX area to coach these changes.
So..... We need to pick a weekend, find a bike(s) to use, make sure experts are available, make sure parts are available and wait for time to pass.
Loren
Denny
Ridgefield, WA
WAK1200LT
Loren
wa1200lt is offline
30MM Socket NOGILLS2 K1200LT 13 Nov 15th, 2008 11:10 am
Extra power socket fitting slparry K1200/1300GT (The Next Generation) 6 Nov 26th, 2007 12:18 pm
Where to get spark plug socket? browad K1200LT 14 Nov 3rd, 2007 1:05 pm
Detail of 30mm socket needed Dean_BMW K1200LT 13 Apr 29th, 2007 11:02 pm
drilled a hole lenny K1200LT 7 Mar 28th, 2007 9:48 pm
