Sputtering LT - BMW Luxury Touring Community
post #1 of 2 Old Dec 7th, 2005, 11:50 pm Thread Starter
Sputtering LT
All,
I have posted something similar to this before in the main forum, but I wanted to throw it out to the "locals" for some feedback.
My 2003 LT has a sputter to it that is driving me nuts. Specifically, at low or no load conditions on the throttle, the bike sputters and burbles like it is missing. At higher RPMs (above 3000 RPMs) and full load conditions like accelerating or climbing a hill, it does not do it. It will also do it if I run the throttle up slowly in neutral and then hold the throttle. I know bike's are not designed to run like this, but I have NEVER had another bike by any manufacturer sputter and burble unless something is wrong.
I have had it in twice to the dealer and I was first told that it was fine. I later took it back and they took the tupperware off, adjusted the TPS, checked the plugs, adjusted the fuel lines, etc. It seemed to be a little better but 500 miles later it is just as bad as before. The outside temp has been cold (30-40F), but other than that, the conditions haven't really changed.
I love this bike, but it just does not run right, and I can't seem to find resolution on the low RPM sputtering. It has 11,000 miles on it.
Any thoughts?
Adventure170 is offline
post #2 of 2 Old Dec 8th, 2005, 1:43 am
Sharkey's Avatar
My roadking did that this summer. I took it back almost every week to the dealer they couldn't find the problem.Then the senior Tech decided to go back to the old ways of trouble shooting and not depend on the computer, and check the connections on the fuel injectors and found corrosion on the wires where they are crimped to the connectors. Replace the wiring and it has ran great ever since.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...holy $hit...what a ride"-Mavis Leyrer
Don't pick a fight with an old man. If he is too old to fight, he'll just kill you. John Stienbeck
08 CanAm Spyder "Fast Truck"(Wifes')
08 Kawasaki KLR 650 "Lil Dirt Truck"
05 K1200Lt "Lt Truck"
05 Piaggio X9 Reveloution "Lil Truck"
97 International 4700 "Big Truck"
AMA Life Member
BMWMOA
Sharkey is offline
Sputtering LT Adventure170 North West 8 Oct 21st, 2005 7:21 am
