Tech Help - BMW Luxury Touring Community
post #1 of 8 Old Jun 20th, 2006, 5:24 pm Thread Starter
Question Tech Help
Hey, guys, need a little diagnostic help. Went to start the lonely LT sitting in my garage and it fired up and then immediately shut off. Put it on the battery charger overnight, green light on so should be fully charged. Went to start again and lights et all were fine and it sounds like things are spinning but nothing resembling a cough, sputter or start. Plenty of fuel, kickstand is up (or down in neutral) . Thoughts??
I'll appreciate your collective experience.
(I figure that the LT is just jealous of my new mistress and is acting up to get attention)
Jeff
Mitch_Rider is offline
post #2 of 8 Old Jun 20th, 2006, 5:55 pm
Jeff
I thought about it being in reverse mode, butt you said it fired up and then immediately shut off! Not sure it'll do that in reverse, so that suggestion is moot - sorry Jeff.
post #3 of 8 Old Jun 20th, 2006, 8:53 pm
amarider's Avatar
Check on the usual
Fuses - motronic, fuel pump.
Kill Switch
Put it in gear then take it out again.
Try starting it with clutch pulled in.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #4 of 8 Old Jun 20th, 2006, 9:07 pm
Jeff
If you hear the starter motor spinning, but the engine is not turning over, it is likely the sprag clutch. Put the bike in gear and rock it back and forth, then try it again. May have to repeat this a couple of times to unstick the sprags in the clutch. Mine did that for a short while, then would not engage even after rocking it back and forth. Finally had to replace the sprag assembly, by far the worst project on the bike I ever tackled.
I have told people that the BMW assembly line must start with the sprag assembly, the the rest of the bike is built around it.
post #5 of 8 Old Jun 22nd, 2006, 10:34 pm Thread Starter
Question Really Strange
Thanks for all the good suggestions.
John,
I checked everything on your list and it all was OK.
David,
I had already done the rocking thing in gear as I have had my sprag clutch replaced once before.
Still Nothing...THEN on a wild hair I held the starter down and opened the throttle all the way...she sputtered for a moment and then shut off. On the third time of doing the same she caught and off she went. Shut it off a number of times and she re-started without a problem as she always has.
WHADYATHINK???
post #6 of 8 Old Jun 22nd, 2006, 11:09 pm
Sounds like the idle circuit was having problems.... that can be caused by several things.
I had a fORD once that the IAC went north on. I disassembled as much as possible anc cleaned... worked a while... finally replaced.. lasted another 50k miles..
If you are gonna "ignore/store" in future put some "StaBil" fuel preservative.... it will burn fine and keeps fuel fresher longer..
Next time you pull the fuel tank check all the linkages and throat of the intakes for buildup.
J.M.J...
Dcn Channing
post #7 of 8 Old Jun 23rd, 2006, 12:15 am
amarider's Avatar
John,
David,
WHADYATHINK???
Fuel Filter got clogged?
John & Cathy
Northern CA
Posse #2
amarider is offline
post #8 of 8 Old Jun 26th, 2006, 6:04 pm
Jeff,
I think that poor child left abandoned and ignored is just jerking your chain.
black1200lt is offline
CCR Tech Session Information johnrehder Curve Cowboy Reunion 51 Aug 26th, 2006 7:01 pm
Spokane Tech Day 5/6/06 -After Action Report usmctpdog North West 6 May 9th, 2006 7:21 am
Tech Day 02lt K1200LT 1 Apr 17th, 2006 9:05 pm
STC Tech Session times and Volunteers, Vendors Info BamaLT South East 7 Jan 27th, 2006 9:25 pm
Tech Session Nov 13th nashty Northern California 37 Nov 14th, 2005 11:27 am
