Fuel - BMW Luxury Touring Community
post #1 of 4 Old Feb 18th, 2016, 8:10 am Thread Starter
Fuel
I recently had my 1200LT serviced. Since that it some times happens that the bike feals it does not get petrol. If I stop and switch it off for a few minutes, it is sometimes ok for a few hundred kilos. Sometimes it happens after a few kilos and some times after 50 or more. Please help
Danie Swart is offline
post #2 of 4 Old Feb 18th, 2016, 12:04 pm
beech's Avatar
Re: Fuel
When you stop with this problem open the gas cap while listening. Does it make a small whosh as air is drawn in? Sounds like while at the dealer maybe a hose got pinched. ??
Beech
beech is offline
post #3 of 4 Old Feb 18th, 2016, 12:39 pm Thread Starter
Re: Fuel
Thanks. Will try
post #4 of 4 Old Feb 18th, 2016, 12:49 pm
want2tour's Avatar
Re: Fuel
What kind of service did they do? While we're considering things, is the fuel filter due for a change and age of fuel lines inside the tank.
If you have a cracked fuel line, You'd see swirling fuel when you look inside tank while bike is running.
Venting is accomplished thru the carbon canister. Is the carbon canister still on the bike (would be under the rear case) and is it plugged?
If you're getting a whooshing sound, it's most likely a plugged canister, probably from overfilling fuel tank. If so, you can loosen fuel cap and not fill too much fuel until you can disconnect canister.
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
Fuel Strip - But not the fuel Strip Thezz RT Series 2 Aug 31st, 2015 8:03 am
'99LT fuel problem, please help mta0202 K1200LT 22 Mar 8th, 2015 8:54 pm
Octane Booster timgray K1200LT 22 Sep 13th, 2013 6:53 pm
Fuel Injector cleaning-on the bike PhillWard Australia, New Zealand, and AsiaPac 4 Nov 28th, 2008 12:02 pm
