2002 brake failure light - BMW Luxury Touring Community
post #1 of 3 Old Apr 30th, 2013, 7:53 pm Thread Starter
I'm confused my brake failure light flashes 4 times per sec and warning light stays on constant. Now I've just put a new battery in and checked all my fluid and they are full to top. When the weather is cool like 50 or below it don't come on till around 10 miles but if I try and reset it by shutting off engine it comes back on within 1/4 mile. Now when it's warm outside 50 or above it comes on within a mile Almost like its a temp problem. When the bike gets warm it starts. My servos still work I can hear them. Any help will be very much appreciated
Mclane26296 is offline
post #2 of 3 Old May 1st, 2013, 11:07 am
blueknightga6's Avatar
Re: 2002 brake failure light
The only obvious help from the Clymer manual from what you describe is "At least one brake circuit (front, rear or both) is operating in residual braking function mode."
Chris Ehlbeck
blueknightga6 is offline
post #3 of 3 Old May 1st, 2013, 4:27 pm Thread Starter
I have no idea what's causing this. I guess I will have to go to bentonville Arkansas to have it coded which is 130 miles Unless someone closer has a gs-911
Until then I'm riding it. NO FEAR. We all have to go out some way.
Repeated critical brake failure with no residual braking Covet_myK K1200LT 16 Dec 30th, 2012 4:44 pm
Problem - Brake Failure Warning Light dbaliko RT Series 61 Oct 7th, 2011 7:01 pm
Triangle Brake Warning Light - A Curiousity... hdironhead78 K1200LT 14 Sep 24th, 2011 2:34 am
Brake failure light keith41902 K1200LT 1 Jun 18th, 2010 1:18 pm
Brake Light Switch jeffklt K1200LT 7 Nov 15th, 2005 3:24 pm
