1600 GTL gear whine - BMW Luxury Touring Community
post #1 of 17 Old Feb 23rd, 2012, 9:25 pm Thread Starter
1600 GTL gear whine
Hi all, I haven't been on the forum for a while, but wanted to post that I,ve purchased a new 1600 GTL 3 weeks ago have taken it in for the first service at 700 miles. Since day one there has been a whining noise that becomes more pronounced above 65 mph, such that you cannot hear the mufflers unless you throttle hard. The dealer test rode it today and says it doesn't sound normal so is going to do a longer test ride tomorrow to try to pin point the source.
Has anyone else had this issue?
On another note, I also find that I have to be quite agressive on the shift from 1st to 2nd or it winds up in nuetral. Dealer says this is somewhat normal!
Any comments are appreciated.
tks
bvick is offline
post #2 of 17 Old Feb 23rd, 2012, 10:14 pm
Re: 1600 GTL gear whine
As far as shifting 1st to 2nd I find it shifts perfectly around 3500 to 4500 RPM's, pre-load the shifter with your foot and just a quick pull on the clutch and it shifts smartly and quickly.
Dave 2012 GT
dderrig is offline
post #3 of 17 Old Feb 24th, 2012, 6:37 am
Dave 2012 GT
+1000
The more deliberate you try to be with the shift, the worse your results will be. Just "kiss" it into gear (after pre-loading) with some decent RPM's and it will reward you with a smooth, precise up-shift. Use this approach for all up-shifts.
BTW, this bike's shifting behavior is exactly like my '99 LT's, so this is not a new thing as far as my experience goes.
Can't help you on the gear whine...the only noises I hear are sweet music.
Good luck getting it sorted.
JimE is offline
post #4 of 17 Old Feb 24th, 2012, 6:42 am
This bike likes RPM.... On this bike everything is better above 3500rpm.. I have no gear whine at all from my bike, sorry.
medauto is offline
post #5 of 17 Old Feb 25th, 2012, 6:43 pm Thread Starter
Just wondering how many miles you have on it and if it had any whine noise when new. The dealer says it is normal for these bikes and it may lessen as I put miles on it, but it definitely has a whine noise (transmission or drive train I think) but figuring out where it is coming from is almost impossible. The dealer says transmission gears are straight cut and do make a little noise. Hmmmm!
bvick is offline
post #6 of 17 Old Feb 26th, 2012, 12:41 am
pushin9s's Avatar
The 1600 sounds much like the 12/1300 engine. I think what you're hearing is the straight cut primary gears from the crankshaft to the clutch basket. BMW uses the straight cut gear over the quieter bevel cut gears due to their superior power transfer. That's all good for me though, because the whine is sheer intoxication. Can't get enough of it. I'd like to get a mix tape of that sweet sound.
Greg
"Loud lives save pipes"
00 K1200LT (Emil) 94,840 trouble free miles. Gone, but not forgotten
02 R1150RT (Artie) 109,000 miles. Favorite bike. With me to the end.
10 K1300GT (The Phantom) 10,110 miles. Like flying a T-38 on 2 wheels. Gone.
12 K1600GTL (Johnny 5) 3,500. A great compromise between the LT and GT
A gaggle of Japanese bikes, then I woke up.
pushin9s is offline
post #7 of 17 Old Feb 26th, 2012, 7:46 am
mwnahas's Avatar
Does it sound like this?
http://www.bmwlt.com/forums/showthread.php?t=59401
Just Go
Cleveland Ohio
mwnahas is offline
post #8 of 17 Old Feb 26th, 2012, 9:53 am
+ on shifting above 3,500.
The higher the better and the smoother it shifts into the next gear. I'm not really used to shifting that high, but it all really comes together much better at a higher RPM. Between 1 and 2, It really makes a difference if you pre-load the shifter.
Pre-Loading = putting a little pressure on the shift lever it before shifting. I don't understand this, but it works!
To me the whine is like the turbo sound of a very expensive sports car. I really can't get enough of it. and out on the open highway, wow!
post #9 of 17 Old Feb 26th, 2012, 11:27 am
messenger13_ver2's Avatar
So the 1600 has the "K-Whine" ... umm ... "feature"? Guess I'll have to hear it for myself, but I hope it's more like my '06 GT was, and NOT like my '02 LT. I did find the whine of my LT to get annoying on long stretches over the super-slab.
As for a required shifting technique to get a smooth shift ... When is BMW going to figure out how to get their bikes to shift like Jap bikes??? I've owned 2 BMWs, and 9 Jap bikes, and the comparison is just silly. Or maybe BMW is just trying to compete with Harley Davidson.
- Just Joe
(Current bikes)
  • 2001 BMW K1200LTC
  • 2010 Kawasaki Concours14
  • 1985 Honda V65 Magna
  • 2005 Harley V-Rod Chrome Edition
  • 2003 Harley V-Rod Anniversary Edition
messenger13_ver2 is offline
post #10 of 17 Old Feb 26th, 2012, 11:35 am
The shifting, when done correctly does require a learned or acquired feel. I had to learn the technique. Not as simple as any previous non BMW bike I've owned and definitely not "plug and play."
The only time I hear the whining is at the peak of a gear change. Never hear it after that. I know that sometime I'll extend the RPM a little just, just to hear it.
post #11 of 17 Old Feb 26th, 2012, 1:03 pm
mwnahas's Avatar
That wasn't a whine you were hearing but the siren from the cop car you were running from.
Just Go
Cleveland Ohio
mwnahas is offline
post #12 of 17 Old Feb 26th, 2012, 5:08 pm
Busted.
- Just Joe
(Current bikes)
  • 2001 BMW K1200LTC
post #13 of 17 Old Jun 26th, 2013, 10:15 am
Picked up a new 2013 GTL 3 weeks ago. Traded a 2004 K1200GT. I rode the GTL a couple of miles without ear plugs on Monday and could not believe the LOUD gear whine and loud CLUNK when shifting. In the lower gears it sounds like a diesel truck turbo spooling up. This racket is obvious even through the ear plugs. There are a lot of great things about the bike, but this racket is a huge step backwards in refinement from my old GT. No shifting problems though as some have reported.
BMWDreamer is offline
post #14 of 17 Old Jun 27th, 2013, 4:08 pm
highroamer's Avatar
The gear whine is one of the reasons I passed on the K1600. No way I could live with it. Pity, because it really spoils a beautiful engine. I had it for a year on a Pan European and that was enough.
highroamer is offline
post #15 of 17 Old Jun 27th, 2013, 4:17 pm
UltraLT's Avatar
I was planning on buying a GTL, and sold my LT in preparation. When a demo was available I took a 75 mile test ride on all kinds of roads. The whine was just one of the reasons I did not buy it, but it was pronounced and annoying. They all do that did not sell the bike for me. I hoped for those who bought one, the noise would subside after break in. I do not know.
Ultra LT
UltraLT is offline
post #16 of 17 Old Jun 27th, 2013, 5:04 pm
Ric
The whine that some like and others dislike is in all K1600's that I have ridden and yes it can make or break a purchase for some. I can't recall which forum I was one, but one K1600 owner had his transmission replaced and saw that most all the driven gears were in fact bevel cut which came as a surprise as it was assumed they were straight cut. Where the whine actually comes from is unknown as best I know. It could be from any number of engine components, but it is a common feature. Perhaps one day I will take a stethoscope to mine and try to narrow down where the whine comes from but for me it is no big deal. Too many other things to worry/wonder about besides a whine. In reality I got used to the whine pretty quick but it certainly doesn't mellow with age or miles.
Rick
Ric is offline
post #17 of 17 Old Jun 28th, 2013, 4:44 pm
johnnyray's Avatar
Whining about engine whine. Go figure. Lovin' my GTL.
Johnny Ray
johnnyray is offline
Take off, 'eh? Starting the LT from stop... petevandyke K1200LT 26 May 30th, 2012 9:48 am
Confirmed Price MERGED KRW K1600GT/GTL 56 Mar 4th, 2011 2:52 pm
A tale of of two gear box's Patric K1200LT 12 Jul 19th, 2010 10:46 am
LT 5th Gear Whine.. KIC K1200LT 5 Dec 2nd, 2007 9:45 pm
Gear Whine Skylark K1200LT 4 May 21st, 2006 9:36 pm
