Removing the rear wheel on a K1600 - BMW Luxury Touring Community
post #1 of 18 Old Dec 7th, 2011, 9:11 am Thread Starter
AFineRide's Avatar
Got a guy in my local BMW riding club for whom I am going to be changing the tires on his K1600. ( I have a tire machine and balancer ).
Anyway, I know the tricks on my RT1200 but I've never removed the rear wheel of a K1600.
Any tips or suggestions? Specialty Tools?
I got a 22mm hex for the the axle nut. I assume it's the same size on the K as it is on the R. Anything else?
Larry
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
AFineRide is offline
post #2 of 18 Old Dec 7th, 2011, 9:23 am
Re: Removing the rear wheel on a K1600
Larry
It seems like the tire pressure sensor can suffer damage while doing the tire change? Let me know if you discover a trick to protecting it.
BEhrler is offline
post #3 of 18 Old Dec 7th, 2011, 1:35 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Pretty easy ,on the rear Just slide the rear mud flap all the way up , Unbolt the tire & roll it out. I did put my center stand on a 1 X 6 just to give it a little more height. The front comes off likes most other BMWs GT, RT & S. I pull the 4 screws in the fender & get it out of the way also.
As far as the tire pressure sensor goes just position the tire so NO tools pass close to the valve stem & be careful getting the tire past the sensor while removing & installing.
Stevie Shreeve
katnapinn is offline
post #4 of 18 Old Dec 8th, 2011, 2:36 pm Thread Starter
AFineRide's Avatar
Ok Thanks. That's easier than the RT. On the RT i have to loosen or remove the muffler.
I don't know if he has a the TPM, but I'll make sure to be careful as I guide the tire tool around the rim.
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
post #5 of 18 Old Dec 9th, 2011, 2:26 pm
Most K16 bikes in the country right now are pre-orders and came fully loaded, i.e. with the TPM.
cbdane is offline
post #6 of 18 Old Dec 9th, 2011, 2:59 pm
mneblett's Avatar
The K16 is designed to be a super-simple, two-step process:
1. Remove the 4 T25 screws holding the rear fender on to drop the entire fender/license plate holder.
2. Remove the 5 Torx bolts (T50?) holding the wheel to the drive, and roll the wheel out the back.
Reinstall axle bolts to 60 Nm.
Mark Neblett
Fairfax, VA
mneblett is offline
post #7 of 18 Old Dec 9th, 2011, 3:00 pm
mneblett's Avatar
The location of the TPM sensor is identified by a readily-apparent sticker on the side of the rim.
Mark Neblett
Fairfax, VA
mneblett is offline
post #8 of 18 Old Dec 10th, 2011, 2:49 am
®win's Avatar
Originally Posted by mneblett
2. Remove the 5 Torx bolts (T50?) holding the wheel to the drive.
Yep. T50 it is.
For the front wheel it requires T45 for the brake calippers and the bolt that secures the front axle, and a hex 22 nut for the front axle itself.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #9 of 18 Old Dec 10th, 2011, 8:16 am
dasmith59's Avatar
Good info guys. Is there a maintenance manual available for the 1600's?
Don Smith
dasmith59 is offline
post #10 of 18 Old Dec 10th, 2011, 2:41 pm
philspace's Avatar
Don Smith
I checked this morning, the REPROM isn't out yet.
15 R1200RT - Ebony Metallic
09 F800GS
philspace is offline
post #11 of 18 Old Dec 11th, 2011, 7:20 pm Thread Starter
AFineRide's Avatar
Thanks for the input. Came off just as you said.
FWIW: Torque Specs;
Rear = 60nm
Front = 50nm
Pinch Bolts = 15 nm
I found the removal of the 190 tire to be challenging. My tire changer had a tough time gripping the lip of the wheel. In the end, we got it done. Unfortunately, I put a scratch on his rim. Anyone know if and where I can get touch up paint for the wheels? 2012 K1600.
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
post #12 of 18 Old Dec 11th, 2011, 7:37 pm
mneblett's Avatar
What brand of tire changer? I'm currently looking at a NoMar, and hoping that wasn't your changer!
Mark Neblett
Fairfax, VA
mneblett is offline
post #13 of 18 Old Dec 12th, 2011, 7:07 am Thread Starter
AFineRide's Avatar
Mark, No. It wasn't a NoMar. It's a brand I bought on ebay. Can't recall the name at the momemt, pro something.
I had modified the clamps by adding the nylon mojo blocks otherwise, without a doubt, every rim would get scratch. In this case, the scratch was caused by the wheel not being clamped down correctly and as I was turning the tool around the rim, the wheel popped out of the clamps and scratched it.
I think I am more upset about it than the owner is. If I can find some pictures of the changer, I'll post it here.
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
post #14 of 18 Old Dec 12th, 2011, 12:51 pm
mneblett's Avatar
Thanks. Sounds like the Harbor Freight-type Chinese changer -- one of which I recently threw into the scrap metal recovery pile at the county refuse facility!
Mark Neblett
Fairfax, VA
mneblett is offline
post #15 of 18 Old Dec 12th, 2011, 7:05 pm Thread Starter
AFineRide's Avatar
It is this one.
http://www.prohoists.com/Motorcycle_Tire_Changer
I didn't pay anywhere near $289 for it.....
You'll notice that the arms that capture the rim have no protection against rim scratching.
I just welded a piece of flat steel to the top of the clamp and added a no mar nylon rim grabber.
It works well. However, on fatter tires, I needed to shave off about a 1/4" above the nylon protector so it doesn't get stuck against the sidewall when clamping down.
Name:	no mar top.jpg
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
post #16 of 18 Old Dec 13th, 2011, 2:00 pm
mneblett's Avatar
That's it -- that's precisely the same unit Harbor Freight sells.
Mark Neblett
Fairfax, VA
mneblett is offline
post #17 of 18 Old Dec 17th, 2011, 12:44 pm
we have a coats 5040 rim clamp at the shop i work at. that is what i use. i just put some pieces of nylon air brake tubing on the rim and it is no touch. no problem w' presure sensors either.
drjohn55 is offline
post #18 of 18 Old Dec 17th, 2011, 7:02 pm
Super Moderator
dfinazzo's Avatar
Saved the day and my Harbor Freight tire changer with the addition of Mojoblocks
http://home.comcast.net/~prestondrake/mojoblocks.htm
I have changed about 5 sets of LT tires with no marring of the rims. They are slippery and you
need to tie one of the main spokes to one of the arms on the changer with a tie strap and viola
- however there is no comparison with No-Mar Changer.
I do however use a No-Mar Demount bar and their tire lube:
http://www.nomartirechanger.com/products/6
Dan Finazzo
dfinazzo is offline
Electronic Cruise Control - R1150RT LaChuparosa RT Series 10 Feb 6th, 2020 9:38 pm
Lose rear wheel lugs! Wootzman Dealer Experiences 6 Nov 16th, 2012 9:45 pm
K1200LT auto rear wheel conversion Tourdog Trailers, Sidecars, & Trikes 10 Feb 26th, 2010 10:37 pm
Rear Wheel Bearing old1951 K1200LT 6 May 10th, 2009 11:35 pm
Rear wheel removal rixchard Tires 4 Jul 5th, 2006 12:40 pm
