Suburban Machinery Peg Relo Kit - BMW Luxury Touring Community
post #1 of 12 Old Oct 17th, 2011, 5:48 pm Thread Starter
I see that suburban machinery finally has a peg relo kit for both the GT and the GTL. I have had them in the past for both my k12 and my LT and they worked great. I was wondering if any one has ordered them for their GT or GTL yet and if so what do they think?
ronk1200lt is offline
post #2 of 12 Old Oct 17th, 2011, 6:10 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Suburban Machinery Peg Relo Kit
Check with DanDiver... I think Dano has a set on his GTL.
Stevie Shreeve
katnapinn is offline
post #3 of 12 Old Oct 17th, 2011, 8:25 pm
I have a set and like them a lot.
miren is offline
post #4 of 12 Old Oct 19th, 2011, 4:12 pm
I have a set on my K1600GTL and like um about 95% of the time.... The only problem is that it makes the rear brake a little challenging to use. I don't the rear brake much so for me it isn't a problem. It's easy to adjust the shifter.
I've thought about a different seat and if I go in that direction, I might sell the peg re-locator, but haven't moved in that direction yet.
I am also scraping the pegs a little more than on my K1200LT. The K1600GTL simply wants to lean more.....
post #5 of 12 Old Oct 19th, 2011, 5:07 pm Thread Starter
Dan! I haven't looked yet, but is there any way to adjust the position of the rear brake lever.
post #6 of 12 Old Oct 19th, 2011, 6:09 pm
I'm not aware of any way way to adjust it.
There is a company that made a lever for the K1200LT's rear brake, but I don't think that they have made one for the K1600GTL, yet.
post #7 of 12 Old Oct 19th, 2011, 6:35 pm
Originally Posted by DanDiver
... There is a company that made a lever for the K1200LT's rear brake, but I don't think that they have made one for the K1600GTL, yet.
If it helps, the company is Ilium Works and their K1200LT brake lever is here.
post #8 of 12 Old Oct 21st, 2011, 11:11 am
I have them as well. They help a bit with knee strain in my case. I haven't had issue with the rear brake lever, but I'm finding difficulty with the shift lever being too high (and it's adjusted to it's lowest posiiton).
Hope this helps...
Jim Lippert
Belmont CA
CCR '01, '02, '03, '04, 05
Current bikes:
'12 K1600GTL (arrived 10/1/2011)
Past Bikes:
'98 Honda PC800
'01 BMW K1200LTC
'05 R1200RT
'05 HD FHLTCUI
"There's a fine line between clever and stupid" -- This Is Spinal Tap
jslippert is offline
post #9 of 12 Old Oct 21st, 2011, 11:44 am
Hope this helps...
There is at least an inch of adjustment on the shifter arm. The adjustment is made on the 8" arm inside the plastic.
I got an email from Ilium Works reference to the brake lever replacement and they are aware of the need and will email me if they decide to build one. The did one for the K1200LT and it took care of the rear brake placement with the Suburban lower peg.
post #10 of 12 Old Oct 21st, 2011, 6:44 pm Thread Starter
Thanks! Dan keep us posted if Illium decides to go ahead and make a brake lever replacement.
post #11 of 12 Old Oct 22nd, 2011, 8:20 am
I don't use my rear brake very often and after the Suburban modification to my K1200LT, I didn't bother with the Illium brake pedal. If there is enough interest, my guess is that the company will speed up the new product.
Anyone wanting the modified pedal:
E-mail the company with your request
post #12 of 12 Old Oct 22nd, 2011, 2:53 pm
lowflyer2000's Avatar
Question Re: Suburban Machinery Peg Relo Kit
Has anyone tried / seen this lowering kit?
http://www.ascycles.com/detail.aspx?ID=122033
2014 R1200RT,
2005 F650GS
If it isn't documented... it didn't happen.
lowflyer2000 is offline
Suburban Machinery Risers mser RT Series 2 Jul 29th, 2010 4:37 pm
Two Suburban Machinery Questions stefeb K1200/1300GT (The Next Generation) 5 Jul 18th, 2008 11:17 pm
Suburban Machinery Footpegs/Clearance Billy Ergonomics & Rider Comfort 36 Mar 12th, 2007 8:45 am
