Shifting the K1600GT - BMW Luxury Touring Community
post #1 of 5 Old Sep 17th, 2011, 2:34 pm Thread Starter
1999k1200lt's Avatar
OK, so I have a whopping 60 miles on the bike, loving it more each mile. But what about this slipper chutch thing? It is probably in the manual, but waht is the real world way to shift normally and like Freddie SPencer (ok, I know, He is old but so am I)
Milton
1999k1200lt is offline
post #2 of 5 Old Sep 20th, 2011, 5:51 pm
murray's Avatar
Re: Shifting the K1600GT
The slipper clutch is a buffer to the pulse of the motor. Just ride the Moe Fo !
Mash the shifter if you want...
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #3 of 5 Old Sep 20th, 2011, 8:11 pm
I have found that shifting up works better (smother) if you preload the shifter. Almost like shifting without the clutch.
Shifting into first from N, if the clutch has been out will make a clunking sound.
Downshifting to slow down, seems to work best for me if, before I shift, I pull in the clutch, let it out slowly to let the engine help slow me down, a little brake and then shift.
Takes longer to explain it than it does to do.
I think this is what I do! and it seems to work.
post #4 of 5 Old Sep 20th, 2011, 8:38 pm
realworld51's Avatar
Milton
Don't even think about the slipper clutch. It comes into the equation only on downshifts to equalize forces between the engine and rear wheel if you don't control downshifts yourself.
Otherwise my GT is extremely easy to upshift, but it's not for the lazy among us. Keep the rpms up a bit for smooth shifts and shift crisply. If you like lazy upshifts, buy an old VW Beetle.
Steve W
Canton, MI USA
2012 K 1600 GT (#901 from 8/6/2011)
realworld51 is offline
post #5 of 5 Old Sep 22nd, 2011, 3:21 pm Thread Starter
Stuck at 5k for another 120 miles.
Milton
Test Ride K1600GT Review - Surrey UK BoxerPilot K1600GT/GTL 0 Jun 29th, 2011 5:12 pm
K1200GT / K1600GT / K1600GTL / K1200LT comparison cbdane K1600GT/GTL 4 Jan 22nd, 2011 4:02 pm
Hard down shifting BigGeo K1200LT 9 Aug 21st, 2009 6:32 pm
Shifting Problems / Gear Indicator Problems rwflier K1200LT 3 Jul 12th, 2008 8:27 pm
Shifting Problems / Gear Indicator Problems rwflier K1200LT 0 Jul 12th, 2008 1:09 am
