Looking for hot wire under seat - BMW Luxury Touring Community
post #1 of 6 Old Sep 5th, 2011, 6:18 pm Thread Starter
larryschumer's Avatar
Great seeing all of you who were at CCR again. Hope to see next year in Duluth.
In case you're interested, you can add a 24" LED strip to run directly off the rear turn signals. However, you cannot add a 48" strip (like I use on the trunk for a taillight) directly to the taillight circuit (CanBus shuts down). I had to use a small relay and ran a wire to the battery.
Has anyone accessed a wire that is turned on with the ignition under the seat? What would be great is a wire that has a great enough load that it wouldn't mind having an LED strip added to the circuit. If you have, can you please describe how to get to the wire?
I only had Jim Montie's GTL for a few hours in my garage, so I didnt' have time to really investigate the wiring. Plus, not being my own bike, I didn't what to destroy anything--he still needed to head back to Florida.
Larry Schumer
Salt Lake City, UT
2003 K1200LT (Black/Yellow) BigBee
Unigo Trailer (Black/Yellow) Stinger
larryschumer is offline
post #2 of 6 Old Sep 5th, 2011, 7:48 pm
Re: Looking for hot wire under seat
I used the red wire on the bike side of the topcase plug. It is a rather large circular plug that is obvious by following the top case wire to it. I have connected my relay trigger wire of a 3 circuit fuse block as well as my P3 lights to it. I have had no problems.
Ute's Chauffeur
stepheg is offline
post #3 of 6 Old Sep 5th, 2011, 10:15 pm
iride4u's Avatar
I use the same red wire to trigger the relay. Anything that uses more power than a relay trigger will upset the Canbus.
2014 K1600 Exclusive
2015 R1200RTP
2018 Hyundai Tucson Limited
Colorado PGR
iride4u is offline
post #4 of 6 Old Sep 6th, 2011, 11:12 am Thread Starter
Thanks guys--that's what I was looking for. I did check power in that connector, with the top case removed. I found a hot wire, but when I connected the top case again, that wire was not hot??? I'm not sure which color it was, but I'm pretty sure it wasn't red. I'll try using the red wire and see what happens.
Larry Schumer
Salt Lake City, UT
post #5 of 6 Old Sep 6th, 2011, 6:33 pm
Matt's Avatar
Why not use something along the lines of a Centech fuse block? You can get them with switched and unswitched outlets. Connects directly to the battery and there's no splicing into the wiring harness.
Matt
95 Honda Magna (sold)
97 R1100RT (sold)
00 LTc, Canyon Red "Tarkus" (sold)
01 F650GS (wifey's, sold)
01 Ducati S4 Monster "LittleOne"
04 R1150RT (turned to scrap)
99 R1100RT Tundra Green
Kalamazoo, MI
"Worry does not rob tomorrow of it's sorrow. It saps the strength of today."
Matt is offline
post #6 of 6 Old Sep 6th, 2011, 8:53 pm Thread Starter
Matt,
This is for my trunk light kit--trying to adapt it to the GTL. The idea is to keep costs down so I don't have to raise the price of the kit.Even adding a small relay adds cost.
Larry Schumer
Salt Lake City, UT
Extra low one piece seat vs low two piece seat, which is better ekuenzli RT Series 11 May 22nd, 2013 7:08 pm
Older seat on ?05 bike pozo_izquierdo K1200LT 7 Apr 13th, 2011 11:07 pm
Front seat STILL won't latch jslom K1200LT 2 Jun 7th, 2010 9:22 pm
BLUE wire kip K1200LT 6 Nov 7th, 2006 10:05 am
