Is there a way to lower the shifter arm a little more? - BMW Luxury Touring Community
post #1 of 6 Old Aug 12th, 2011, 4:43 pm Thread Starter
I recently installed the Suburban kit to lower the foot pegs of my K1600GTL and the lowering went well. Problem with the shifter being too high. There is a very tiny adjustment that can be made by loosing the screw on the small extension, but that is not enough.
It looks like the long connector rod that is about 8 inches long can be adjusted. Will this cause a shifting problem if I loosen this rod and allow it to extend another 1/2 inch or so?
I have the same problem with the brake, but I'll work on one at a time...
post #2 of 6 Old Aug 12th, 2011, 5:02 pm
Re: Is there a way to lower the shifter arm a little more?
I was wondering the same thing. Distance from the peg to shift lever seems a little high when going to 5th and 6th. Owners manual describes an adjustment but I haven't had time to try. Also, the procedure don't look like it will change much. I didn't notice till after my initial dealer service.
Doug Sorchilla
La Quinta, CA
2012 K1600 GTL
Growing Old is Mandatory Ė Growing Up is Optional
sorchilla is offline
post #3 of 6 Old Aug 12th, 2011, 5:29 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Yes it is very easy. Just above the left foot peg / shifter there is a silver plastic cover with the # 6 on it. Remove the 2 screws & you will see the upper shifter arm that connects the shifter rod to the shifter shaft on the motor. Loosen the bolt on the shift arm (you might have to remove bolt) & pull the shifter arm off shaft. Turn it a few teeth over then reinstall. Check the foot shifter to see if it was moved enough. If so tighten up the upper shifter arm. If not remove & turn it some more.
Not sure about the brake as I have not had to move it yet but I will as it is too low for me.
Stevie Shreeve
katnapinn is offline
post #4 of 6 Old Aug 12th, 2011, 5:59 pm Thread Starter
Thumbs up Re: Is there a way to lower the shifter arm a little more?
Thanks Steve... I was looking at that and wanted a little reassurance before I started to adjust it.
post #5 of 6 Old Aug 14th, 2011, 10:27 am Thread Starter
OK - Here is what you do to adjust the shifter arm.
After removing the cover plate ( two screws) that has the 6 on it, you also remove the cover that surrounds on 3 sides of the small lower key open compartment. Three screws and one is a #20, not #25 you have access to the 8'' shifter link to the transmission. It can be extended at least another 3/4 " . Where it connects to the transmission (loosen screw with a # 8 star socket) and there is room for more play if you need it.
The linkage between the transmission and the shifter is open and easy to service too.
post #6 of 6 Old Aug 18th, 2011, 12:26 pm Thread Starter
After getting the star socket #8 tool and then adjusting where the linking rod meets the transmission shaft I determined that making any change there would not work with the previous adjustment that I made to the linking rod. Bike would not shift down into 1st gear.
There is a hash mark on the transmission shaft that matches up with the clamp and I put the clamp back where it was before I moved it and made another slight adjustment to the shifting rod. It seems like the 8" shifting rod has about an 1 & 1/2" of play that can be worked with.
After a short ride, the placement of the shifter and the new pedal location seem to be just right. It would be nice if the actual shifter (covered in rubber) that is about 2" long were about another 1/2" to 3/4" longer. Because of the heat, my left foot is a little further out and the Suburban pedal also swings my foot out a little more. Seems like the heat varies from hot to hotter.
It really is nice the way the shifter linkage is exposed so that an occasional lub is quite easy.
Lower coiled comm cords Dick Intercom, CB, & 2-Way Radios 0 Feb 19th, 2011 1:19 pm
How do I lower my shifter? mrbiker K1200LT 7 Feb 9th, 2008 10:53 am
Update on shifter linkage BobfromSWOhio K1200LT 1 Nov 10th, 2007 10:50 am
Reattaching Shifter Linkage Reid K1200LT 7 Jul 28th, 2007 8:38 pm
Shifter..! EzyMount K1200/1300GT (The Next Generation) 5 Apr 22nd, 2007 4:59 pm
