Top speed limitator + more Impressions - BMW Luxury Touring Community
post #1 of 21 Old Jul 18th, 2011, 4:01 pm Thread Starter
Just back from a 3900 km (> 2400 miles) ride in Europe, in particular the Alps of Austria and Italy.
It is quite much easier to hande on the narrow serpentine roads of the Alps, The 40 kg less and probably a much lower weight point help a lot.
Top speed: there has been some rumours and statments that the GTL do have an in-built speed limitation of 220 km/h ( 137 mph), in reality, at laest on my GTL it made 240 km/h ( 150 mph) on the meter ( the GPS showed 229 km/h=142mph).
The experience was made on the german Autobahn in good driving conditions.
Advices: the screen must be in lowest position, the ventilation flaps should be closed, sit as much back as possible to minimize the space between driver and topbox
ID:	32136   Click image for larger version
Superswede is offline
post #2 of 21 Old Jul 18th, 2011, 4:26 pm
petevandyke's Avatar
Re: Top speed limitator + more Impressions
I'd like to be the first to say "I am ridiculously jealous"
petevandyke is offline
post #3 of 21 Old Jul 18th, 2011, 4:35 pm
crosswrap's Avatar
Have you experienced the rev limiter in other gears? It normally kicks in a few past the posted red line. The top speed limit is the same function I believe. On my bike it was in the area of 240K. May be you haven't gotten there yet?
crosswrap is offline
post #4 of 21 Old Jul 19th, 2011, 1:08 am Thread Starter
It is sure not a rpm-limiter, but a speed limiter.
At 240 km/h , the rpm was between 6k-7k. It does not cut off ignition but feels more like it does limit the amount of fuel injected.
And it accelerated well all the way to 240, there is a lot of more power left that will never be used because of the limitation
post #5 of 21 Old Jul 19th, 2011, 4:55 am
..... and another interesting feature is the the speedometer is pretty accurate. I noticed that when it read 70, my GPS read 68-69.
post #6 of 21 Old Jul 19th, 2011, 5:49 am
where exactly is that road you pictured? I must go there. wow
wdwrkr is offline
post #7 of 21 Old Jul 19th, 2011, 7:49 am Thread Starter
In Sweden, legislation / regulations require less accuracy, consequently the manufacturers deliver less accuracy.
Typical the speedometer shows 5% too much
post #8 of 21 Old Jul 19th, 2011, 7:54 am Thread Starter
The left picture is a place in Italy called Passo Stelvio and the right picture is Passo Rombo ( german Timmelsjoch) between Austria and Italy.
I add 1 more picture of Stelvio take from bottom of the valley and another one from Timmelsjoch
PS. Stelvio is 2757 m above ocean level and Rombo is 2509 m.
ID:	32143   Click image for larger version
post #9 of 21 Old Jul 19th, 2011, 10:11 am
powwow's Avatar
I was happy with my LT until I started reading these GTL posts....of course, now I can't STOP reading them!!! ARRRGGGGG.
Life happens...you control your reaction.
2017 KTM 350 EXC-F (single track monster)
2018 Honda CRF250L Rally (fun on the fire roads)
2015 R1200 RT (holy cowwhat a bike)
2007 K1200 LT (sold)
2005 DR 650 (sold)
2002 Harley Ultra (sold)
1999 Harley Road King (sold)
1996 K1100 LT (sold)
1990 Honda Shadow (sold)
1978-1993 Raising Kids; Paying Mortgages
1975 Honda CB550 (sold but wish I still had)
Homemade Motor Bike (mounted a 3.5 HP Briggs & Stratton on my bicycle at age 12)
powwow is online now
post #10 of 21 Old Jul 27th, 2011, 3:44 pm
Slade2's Avatar
Wink Re: Top speed limitator + more Impressions
Looks like you had mutch better weather than we did when we were there 2 years ago.(it was very cold and snowing)
How was the 1600 in all those hairpin corners?
slade 2
Slade2 is offline
post #11 of 21 Old Jul 27th, 2011, 4:22 pm
Well, my GTL was showing 240 on the speedometer, but ded on 220 on the GPS!
As yours - accelerate as a demon all the way up to full speed - and then stopped.
1/3 of the throttle left - but nothing happens when trying to find the last 1/3
A video from the alps - Grosz glockner - two K1600 up the hill some 6min into the video - in perfect weather - 3 weeks ago !
http://video.my-mc.com/showvideo/71.html
STeinar
fremme is offline
post #12 of 21 Old Jul 27th, 2011, 6:47 pm
STeinar
From a throttle perspective the engine is at full power when the throttle is at 60% while in dynamic mode unless, in your case, the electronic stop takes over.
TVKGTL is offline
post #13 of 21 Old Jul 27th, 2011, 8:40 pm
roadcrave's Avatar
Were you running in dynamic or road, I heard today that affects top speed I did 120 on a k1200gtl today and seemed to top out, if i had a longer straight it might have eased to 137 from 4500 to red line it was loosong its pull?? on this Demo bike
roadcrave is offline
post #14 of 21 Old Jul 27th, 2011, 11:53 pm
Full throttle in road or dynamic will give you the same amount of power, rain mode is less. Try using 5th gear.
TVKGTL is offline
post #15 of 21 Old Jul 28th, 2011, 6:12 am
Raaze12's Avatar
I've been past 125 (indicated, on GPS) on my GTL in Road mode, and there was definitely more available. I only stopped there because the bike was starting to get a little squirrelly (likely due to the top case).
'12 K1600GTL - Mineral Silver
Raaze12 is offline
post #16 of 21 Old Jul 28th, 2011, 2:23 pm
roadcrave's Avatar
if you look hard enough you will go blind they say...
post #17 of 21 Old Jul 28th, 2011, 2:29 pm
roadcrave's Avatar
another Web forum with pics shows some k 1600s from the factory pulling left and the front paralever is not in alingment ill see if i can find it and give you guys a jump to it.,on some bikes off the assy line at high speeds the bike is unpredictable, the fix was to shim the paralever over.alingning the front wheel to the rear..matthew
post #18 of 21 Old Jul 28th, 2011, 2:42 pm
roadcrave's Avatar
http://www.k1600forum.com/forum/bmw-...-approach.html
post #19 of 21 Old Jul 28th, 2011, 3:35 pm
hallzee's Avatar
I am jealous.... In my opinion, the roads in the Alps are the best in the world for riding. Awesome twisties, and impeccably maintained for the most part (the ones I've seen anyway)!
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #20 of 21 Old Jul 28th, 2011, 5:32 pm
Agreed. Awesome roads and amazing scenery. I still miss it . . .
And the best part is that they built all these impressive tunnels so that the majority of truck and commuter traffic stays down on the motorways below, leaving the mountain passes for bikers, tourists, and the occasional bicyclist.
It's simply an awesome place to ride, and should be on every biker's bucket list.
post #21 of 21 Old Jul 29th, 2011, 4:07 am Thread Starter
Dynamic. of course. Thought Rain or Road are for chickens
The GTL is heavy and should be handled with respect. Best is to, if possible, to look up- or downwards, to make sure you do not meet anyone else in the middle of next corner.
It is easier to handle in the hairpin corners than the K12LT was.
I have no experience, but I suspect the GS's are easier to handle, except the fact they are high and might be a problem if you have to stop in one of the ,pretty much, sloped bends
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
ST-1300 to K-1200 LT First Impressions AlexKilpatrick K1200LT 8 Jan 3rd, 2011 5:04 am
Speeeeeeeed. cfell Bike Talk 21 Nov 9th, 2008 8:16 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
