Power outlet below the battery compartment on the left side ? - BMW Luxury Touring Community
post #1 of 12 Old Jul 16th, 2011, 11:47 am Thread Starter
Seems like a strange place to put a power outlet.
Any idea what it is intended for ?
I just checked it with a cable and it is hot all the time.
post #2 of 12 Old Jul 16th, 2011, 1:01 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Power outlet below the battery compartment on the left side ?
Coffee pot, 12 volt vacuum cleaner,Passenger heated clothing.
Yes it is a dumb place for it & so is the front one. Every heated vest, pants etc... I've ever seen has wires on the left. I had to buy an extension for Sammies' just to reach the socket.
Stevie Shreeve
katnapinn is offline
post #3 of 12 Old Jul 16th, 2011, 3:34 pm
On the K1200GT that power outlet was for a canbus smart charger. not much good for anything else because of its location and current limitations.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #4 of 12 Old Jul 16th, 2011, 3:53 pm
The power outlet is on the right side below the battery. I assumed it's only hot when the bike is on or one minute afterwards.
CGameProgrammer is offline
post #5 of 12 Old Jul 16th, 2011, 5:10 pm Thread Starter
You are correct and I still have a lot to learn about this bike. When I checked it, after turning off the key, it was hot, but that must have been because it was less then a minute.
Seems like it could be wired directly to the battery and made more useful.
post #6 of 12 Old Jul 17th, 2011, 7:53 am
realworld51's Avatar
Check out this thread at k1600forum.com to connect direct to the battery.
Steve W
Canton, MI USA
2012 K 1600 GT (#901 from 8/6/2011)
realworld51 is offline
post #7 of 12 Old Jul 17th, 2011, 1:18 pm Thread Starter
Thanks - I saw that article, but wasn't sure if that was exactly what he did. Looks like he wired up a different connection though. I'm thinking of using the connection that is there and just wiring it directly to the battery since it is there and the connector is the universal one that BMW uses.
I don't like having to go back and forth between the two sites, but there is a lot of information on the other site that is relevant to the K1600.
post #8 of 12 Old Jul 17th, 2011, 7:27 pm
mneblett's Avatar
I chose to replace the OE socket with a "full power" socket (one of the K12LT trunk passenger outlets) wired directly to the battery, instead of reusing the low-current stock plug with an adapter harness.
In other words, I wired it the same as you are talking about (direct from socket to battery (of course, via a fuse)), but at the same time upgraded the socket.
BTW, the connector to the socket is not the same as on the older sockets -- smaller, lighter wires, different shape. The old sockets and new connectors on the bike won't mix (and vicey-versy).
Mark Neblett
Fairfax, VA
mneblett is offline
post #9 of 12 Old Jul 26th, 2011, 8:04 pm
crosswrap's Avatar
Getting set to hook up my Fiamms and noticed there is a fused two prong direct to the battery hook-up on the bike from the factory. All you have to do is lift the seat and attach tender etc. there. Neat.
crosswrap is offline
post #10 of 12 Old Jul 26th, 2011, 8:11 pm
mneblett's Avatar
Actually, likely installed by your dealer (mine is starting to do that with deliveries, I believe). Definitely not factory.
Mark Neblett
Fairfax, VA
mneblett is offline
post #11 of 12 Old Jul 26th, 2011, 8:36 pm
Any photos?
BEhrler is offline
post #12 of 12 Old Jul 26th, 2011, 9:50 pm Thread Starter
I did the same to mine for charging the battery ( my demo was set up that way) and it it not necessary to raise the seat. There is enough slack so that it can be reached in the space below the seat and beside the battery compartment. Just plug in the tender.
more power (voltage outlet) baker K1200LT 4 May 9th, 2009 8:28 pm
Battery charger through power socket 02lt K1200LT 13 May 6th, 2009 12:38 am
Picture of Battery Compartment KMC1 K1200LT 6 May 27th, 2007 9:29 pm
Additional Power outlet FredR Batteries, Chargers, & Electrical 4 Mar 12th, 2006 10:32 pm
