K1600 Maintenance? - BMW Luxury Touring Community
post #1 of 8 Old Jun 26th, 2018, 5:26 pm Thread Starter
drmajor's Avatar
K1600 Maintenance?
Thinking of K1600. Presently have LT & GSA and work on them.
How hard is K16 maintenance for DIY?
Cost to have valves done?
How hard to do valves yourself?
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 8 Old Jun 27th, 2018, 1:39 pm
Re: K1600 Maintenance?
Well the transverse engines do require you to pull the radiator just to get to the valves for a check. Not hard but time consuming. Good news is they usually don't need adjustment. Then once it is back together you have to vacuum fill (special non-BMW tool and not expensive) the coolant as you cannot gravity fill. Other than that they are just like every other BMW. On the oil change you pull the drain plug and then go in through that hole to pull another one. You will need the newer GS-911 to reset the service reminder.
post #3 of 8 Old Jun 27th, 2018, 2:57 pm Thread Starter
drmajor's Avatar
Thank you...
Vacuum the coolant?
What tool?
Is there a point/connection on cooling system to do this?
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #4 of 8 Old Jun 29th, 2018, 12:00 pm
This is the tool you need to draw a vacuum on the system and then let it suck the coolant in.
Name:	Vacuum coolant.PNG
post #5 of 8 Old Jun 29th, 2018, 12:02 pm Thread Starter
drmajor's Avatar
Thank you.
Does that kit have all that's needed?
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #6 of 8 Old Jun 30th, 2018, 9:27 am
It appears so but I have not used it yet but I have watched a video of the process and it has everything the one he used did.
post #7 of 8 Old Jun 30th, 2018, 9:44 am Thread Starter
drmajor's Avatar
Thanks.
Have a good weekend!
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #8 of 8 Old Jun 30th, 2018, 10:15 pm
This tool will not work as you do not have the space to insert it in the radiator cap opening.
I use the Mityvac MV4535 Cooling System AirEvac Kit that I had to modify the rubber cone fitting by using a 90 degree 1/4 inch pipe thread elbow to which I epoxied the chrome fitting to and the other end I use a 1/4 inch pipe thread to barbed fitting. This provides the proper clearance to do the job. I used it on my K1600GT this spring to do the 18,000 miles maintenance and also lend it to my friend to do his K1600GTL.
A not of caution when doing the maintenance, you have to remove the plastic pipe on top of the valve cover. Do not follow the service manual instruction for this as you will break that pipe and it will cost you ~$100 for a replacement. The safe alternative is to use a thin bit holder ratchet with the proper bit (You will need to cut about 3/16 inch from the torx bit hex end to get the proper clearance) and remove the screw securing the 3 aluminium covers that the pipe connects to.
Since your radiator is removed, get it to a radiator shop and ask them to clean the outside of the core by soaking it, this will get your running temp back to normal.
For the replacement Anti-freeze, go to your local BMW Car dealer and buy a gallon of the anti-freeze (Paid $23.00CDN for 3.8Litres at my local dealer) (it's the same as they use in the motorcycle), Also buy 1 gallon of Distilled or De-Ionized Water to mix with the Anti-freeze in a 50/50 mix. Find a clean container that holds 1 gallon and mix the Anti-freeze and Water before use.
For the spark plugs, here is a ling to order them for $12.06 each; https://www.ngk.com/product.aspx?zpid=46681
You will have to plan about 6 hours to do the 18,000 mile maintenance (Engine Oil and filter change, Final Drive oil Change, valve clearance check and spark plug replacement
Robert
Proud Owner of a 2016 Cosmic Blue K1600GT since Nov 16 2015
frenchnew is offline
K1600 reliability compared to LT? Alpac K1600GT/GTL 13 Aug 7th, 2016 10:58 am
K1200LT - Lot's of maintenance? Leboyd K1200LT 38 Sep 12th, 2015 10:21 am
Maintenance & other questions Dean_BMW K1600GT/GTL 5 Sep 3rd, 2012 4:08 pm
RT Maintenance Costs COMike RT Series 0 Apr 11th, 2010 9:58 am
Yearly RT Maintenance Cost Xavier6162 RT Series 12 Nov 18th, 2007 8:44 pm
