Water pump leak on 2014 GTL - BMW Luxury Touring Community
post #1 of 4 Old Dec 13th, 2015, 12:32 am Thread Starter
Hi all
I have read a lot of threads on the leaky water pumps. I noticed after 6k miles there are some blue spots on the heat shield.
Had anyone else had this issue on a 2014 model?
Is there a permanent fix for this? I read some have had theirs replaced 4 and 5 times on a 2012 model.
Do we know what what is the root cause?
Erick
ehaughn is offline
post #2 of 4 Old Dec 13th, 2015, 12:33 pm
Re: Water pump leak on 2014 GTL
The water pump issue has pretty much been solved, but it can still occur on rare occasions.
Fortunately, it's not immediately critical, and the bike can still be ridden just fine.
It's most likely just a weak seal, or a buildup of machining tolerance errors.
Just ride in to your dealer at your convenience, and let them swap the water pump out for a new one.
Might want to take some pics if you can't get the bike in right away, just for the record.
post #3 of 4 Old Dec 15th, 2015, 10:17 pm Thread Starter
Took some pics of the leak today. Appears to be coming out of the weep hole.
ID:	95154   Click image for larger version
ehaughn is offline
post #4 of 4 Old Dec 16th, 2015, 9:28 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
There have been some post on the K1600 Forum where owners were told by their dealers to not worry about a few drops coming out. In most cases the pumps stopped leaking by there selves. A few had to be replaced. Just to be save have your dealer make the call on that.
Stevie Shreeve
katnapinn is offline
Water leak from bleed hole BigKev GS Series 6 Aug 23rd, 2014 9:26 am
Strange water leak BigKev RT Series 0 Jun 30th, 2014 1:41 pm
BMW fuel pump vs GM fuel pump kclineman10 K1200LT 14 Feb 18th, 2011 1:48 pm
Water Steve_R Humor 1 Sep 18th, 2006 9:06 pm
Oil Leak around Water Pump Housing nocanpickem K1200LT 1 Jun 26th, 2006 5:47 pm
