Battery charing tender options - BMW Luxury Touring Community
 2Likes
  • 2 Post By katnapinn
post #1 of 7 Old Dec 11th, 2015, 1:24 pm Thread Starter
Hello all
I have a 2014 GTL and I am curious what is the recommended method for using a battery tender. I see some are using CAN BUS and others are direct to the battery.
I would hate to remove the battery every time I want to charge or use the trickle charger.
ehaughn is offline
post #2 of 7 Old Dec 11th, 2015, 2:44 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Battery charing tender options
The dealer install my tender pigtail direct to the Battery. They then asked what side of the bike I wanted it to come out on (which side of bike faced a wall plug). All my bikes have had the tender hooked direct to the battery.
DanDiver and beech like this.
Stevie Shreeve
katnapinn is offline
post #3 of 7 Old Dec 11th, 2015, 3:44 pm Thread Starter
What type of tender do you use
ehaughn is offline
post #4 of 7 Old Dec 11th, 2015, 11:28 pm
beech's Avatar
Whatever you buy use it regularly. Also I suggest you install an extra socket wired directly to the battery with a 15 amp fuse. It will be useful for heated gear, an air compressor and your battery tender of choice. Powerlet has several types of sockets to choose from or a OEM is nice. There is a stock OEM with 4' of wire and an inline fuse.
65 142 153 835
It is very nice. I put one on my S bike that has few sockets on it.
Here is a good charger and you can set it either for use in your CAN bus socket or in a non CAN bus socket. If you buy an extra socket and hook it up to the battery you can buy one of the non CAN bus rated chargers for a few dollars less.
Amazon.com: OptiMate 4 DUAL PROGRAM BMW CAN-bus edition: Automotive
This charger will monitor your battery and charge as needed. Tell you if your battery is dead as in one thread here. It will de sulfate a battery. I even use it on my seldom driven '82 izuzu truck, now have a # 6 optimate for that.
Beech
beech is offline
post #5 of 7 Old Dec 12th, 2015, 12:10 am Thread Starter
Thanks beech. I like your avatar. I had a shirt with Krusty on it for many years. Gota lover those simpsons.
ehaughn is offline
post #6 of 7 Old Dec 12th, 2015, 6:31 am
katnapinn's Avatar
My dealer also agrees this one is the best for the K1600
Optimate 4
Mine is plugged in any time my bike is in my garage. Been using it for 4 1/2 years with zero problems.
Stevie Shreeve
post #7 of 7 Old Dec 12th, 2015, 4:25 pm Thread Starter
Thanks all. I just ordered the optimate 4 dual.
ehaughn is offline
Another Battery Tender (BT) Question. Benito RT Series 18 Nov 3rd, 2012 4:15 am
Battery Tender mikeinpgh Batteries, Chargers, & Electrical 3 May 28th, 2007 2:04 pm
Battery Tender Clicking Sound and Error Light Lopaca Bike Talk 3 May 11th, 2007 7:35 pm
Bike only 14 months old - battery problems Thor1340 K1200LT 14 Aug 30th, 2006 4:59 pm
Battery Tender "routine"?? mconlogue Batteries, Chargers, & Electrical 3 May 3rd, 2006 6:06 pm
