Top case removal - BMW Luxury Touring Community
post #1 of 10 Old Jul 28th, 2015, 1:33 pm Thread Starter
Top case removal
I have a K1600 GTL Exclusive, and the radio antenna is located in the top case. I am thinking of taking the topcase / back rest, and arm rests off since I do not have a regular rider. It looks simple to remove, the armrest are a little more difficult. I guess the problem will be that you lose the radio antenna. I can live with out the radio, but where is the Sat. antena?
Has anyone tried this? Do you have any advice?
martin18152 is offline
post #2 of 10 Old Jul 28th, 2015, 9:22 pm
Re: Top case removal
The Exclusive was envisioned as a two-up tourer, so BMW figured people wouldn't be removing the trunk all that often. Yeah, I know . . .
Removing the trunk is pretty easy, but you will lose AM/FM reception.
Satellite Radio will still work, as that antenna sits up front above the GPS.
And of course, so will iPod/USB.
See this link for more details and some pics.
The armrests take a bit more to remove, as they're bolted down to the frame (as they should be).
Some riders have had a local shop modify their armrests so they can be removed with two bolts.
post #3 of 10 Old Jul 31st, 2015, 4:34 pm
I only use the Top Case for long haul rides or when two-up. only when two-up are the armrest on. The link in Ken Meese post is what I did to remove the Arm Rest. The modification is well worth the $ to have it done. I can remove or reinstall the top case and armrest in 5 minutes max.
Doug Sorchilla
La Quinta, CA
2012 K1600 GTL
Growing Old is Mandatory – Growing Up is Optional
sorchilla is offline
post #4 of 10 Old Aug 1st, 2015, 6:43 am Thread Starter
Yeah it looks easy to remove. In the post they talk about additional wires. I think they got rid of those wires in the 2015 exclusive. I looked at mine and everything seems to be in the single connector which makes it really easy. For now I need the top case for storage on long trips. I just bought the bike a few weeks ago and I'm trying to use it as much as possible before the summer ends. One thing the bike really needs is foot pegs. I have them on order, after about 300 miles your legs start to get cramped, at least mine do. I had to sit on the passenger seat for few miles.
post #5 of 10 Old Aug 3rd, 2015, 6:55 pm
Tallyho's Avatar
There are three connections that come out of the single cable under the seat on the Exclusive. Radio antenna, backrest heat, and tail light. Two are zip tied in place. The armrests take about an hour to remove the first time you do it. The main trick is removing the rear fender to access the two bolts inverted horizontally that secure it from the underside. Can be done without removing tire.
Bob Morrow #4204
2014 K1600GTLE "Firefly" GTL 4 Two
2002 K1200LTE "Green Hornet" LT 4 Two (history)
"Kyrie Eleison down the road that I must travel"
Tallyho is offline
post #6 of 10 Old Aug 6th, 2015, 8:45 pm
So...do I have to remove / disconnect all 3 wires as one disappears behind some plastic? All 3 wires form my top case are in a sheath. Do I have to remove the sheath at all? I have a 2014 GTLE and also want to remove the armrests. Can the top case just be slid aside without disconnecting the wires for armrest removal? Also, when I unlock the top case, it appears that only the rear of the top case can be lifted up and the front of the top case is still attached. Is there a trick to lifting up the top case??
Eric109 is offline
post #7 of 10 Old Aug 7th, 2015, 2:38 am
There's a large, round barrel connector under the passenger seat for the top case, and another antenna lead. Unplug both of those, and fish the wires out from under the passenger grab rails.
Unlatch the top case, lift the rear, and pull the whole things towards you (back and then up). Make sure the wires are free and clear.
To put the top case back on, reverse the above steps.
The armrests aren't meant to be quickly or easily removed. They bolt solidly to the rear frame, so it's kind of a pain to get all the bolts loose to remove the arm rest frame.
Some riders have had their arm rests modified by local machine/welding shops to leave the lower portion attached to the frame, and then use only two bolts to remove the upper portions. See this thread over at the K1600forum.com for details and pics.
post #8 of 10 Old Aug 7th, 2015, 8:19 am
I also have a 3rd wire for the heated back rest on the Exclusive. I'll look and see if I can fish that one out too as there is a sheath over all 3 wires that I would prefer to preserve. I've seen the quick-release modifications people have made and am planning on doing the same but have to remove the armrests for the modification. Also, is it true that the topcase on the Exclusive is only am/fm antenna? Someone earlier said that the XM antenna is located up front but I can't see it.
Eric109 is offline
post #9 of 10 Old Aug 7th, 2015, 10:33 am
Never mind about the third wire; it is a ground so it is easily enough removed. Still wondering about the satellite antenna located in the front or if it is part of the top case. Thanks.
Eric109 is offline
post #10 of 10 Old Aug 7th, 2015, 11:20 am
The Satellite Radio antenna is mounted in the plastic dash shroud just above the GPS.
top case removal survey billsmith K1200LT 21 May 27th, 2011 12:58 am
Thread for top case removal? flyby K1200LT 12 Nov 2nd, 2009 10:32 am
Trunk low case broken by heavy top case? KHLT K1200LT 15 Mar 3rd, 2009 3:12 am
Top Case Support Strap Attachment? tgburnett K1200LT 10 Oct 10th, 2008 6:34 pm
