Top box rear lighting question - BMW Luxury Touring Community
post #1 of 4 Old Mar 26th, 2015, 7:06 pm Thread Starter
gdroege's Avatar
Have our eye on a new/used 2014 K1600GT with only 700 miles. Obviously need to add a top box for wife's comfort but am told the rear trunk light is for brake light only. Is there a way to enhance the top box light so it can also be a running light as well as a brake light?
Still riding a 2008 LT which has a trail blazer light built into the trunk rack light. It has saved our a$$ on numerous occasion while pulling our Unigo trailer.
Haven't pulled the trigger yet, but am getting dangerously close.
Any advice on improving rear visibility would be greatly appreciated.
Gary & Mary Droege
1999 K1200LT
2008 K1200LT
"Life ain't about how fast you run, or how high you climb, but how well you bounce."
gdroege is offline
post #2 of 4 Old Mar 26th, 2015, 9:05 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Top box rear lighting question
Hey Gary, Here is a video of my tail light flasher I installed. Since this video I have also turned the light into a running light. It stays on at about 1/3 power for the running light till I hit the brakes then comes on full.
Both parts to do both conversions was less the $65.00 total & very easy to install.
Here is a thread on the K1600 forum that talks about it.
https://www.youtube.com/watch?v=h9iw90f4EQA
Stevie Shreeve
katnapinn is offline
post #3 of 4 Old Mar 27th, 2015, 5:06 pm Thread Starter
gdroege's Avatar
Steve, thanks for your suggestion!
If I get the GT, I will give it a try.
Gary
Gary & Mary Droege
1999 K1200LT
2008 K1200LT
gdroege is offline
post #4 of 4 Old Mar 28th, 2015, 8:44 am
PadG's Avatar
Actually, the subject had been heavily talked about on the RT side of the forum, since the topbox for both are the same. If you don't have the Clearwater lights (with Canopenner) on the bike, then the cheapest solution is to add Skene's controller: Skene Design Motorcycle Visibility Lights. $54.99. This will give you direction to convert your topbox LED: Skene Design Motorcycle Visibility Lights
NOTE: One member that did this installation did not like the result, even though the topbox LED did exactly what he wanted. He had two complaints, and that was with the installation, the inside light of the topbox flickers. The second complaint was that the Skene controller is very hard to configure (having to press the brake in certain sequence within 5 seconds of power-up).
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
Question about Metzler 880 Rear tires. URGENT BMW_forever K1200LT 36 May 24th, 2015 11:55 pm
NooB Rear Brake ReservoirTuperware Question Fun Bobby K1200LT 2 May 18th, 2014 8:36 pm
Rear brake question Artm635 RT Series 16 Apr 19th, 2014 1:30 pm
Rear Drive Question ceclark K1200LT 11 Feb 19th, 2012 11:14 am
Very specific wiring question - Rear Speakers midwilshire Intercom, CB, & 2-Way Radios 11 Nov 21st, 2011 4:37 pm
