Transmission & Final Drive Oil Change - BMW Luxury Touring Community
post #1 of 5 Old Aug 7th, 2014, 4:15 pm Thread Starter
I am getting ready to change the fluids in my K1600 and see that BMW recommends Castrol 75W90 synthetic oil but I can't find the volume required for the transmission or final drive. Does anyone know how much oil each one takes?
VinnytheBlade is offline
post #2 of 5 Old Aug 7th, 2014, 4:52 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Transmission & Final Drive Oil Change
First the Transmission is part of the Motor & shares the motor oil so you only need to change the FD unless your changing the motor oil too. If so the motor holds 4.75 quarts but will hold 5 quarts. Put in the first 4 then start the bike. Add 5th quart while bike is running. if you do NOT start the bike after 4 qts you will not get all 5 qts in.
The FD holds 200ML
Stevie Shreeve
katnapinn is offline
post #3 of 5 Old Aug 7th, 2014, 10:03 pm
Steve - the BMW Service Manual claims 180 ml for the final drive . . .
post #4 of 5 Old Aug 8th, 2014, 6:05 am
katnapinn's Avatar
About 6 months after the K1600 came out there was a service bulletin stating to use 200ML not 180Ml. it is some where on the K1600 Forum but I just can't find it right now. I think RL posted the update.
Stevie Shreeve
post #5 of 5 Old Aug 19th, 2014, 10:24 am
180ml is the correct amount. I use a bottle and fill it to about 190ml and get as much in as possible. Emptying all the oil from a container is difficult. I figure I get something more than 180 and less than 190 in it. That'll do.
Greg
2011 R1200RT (sold)
2012 K1600GTL
GRB60 is offline
Final drive oil Marve RT Series 9 Jan 28th, 2014 1:04 pm
How To Do A $65 Oil Change For $13 southern_nj K1200LT 109 Sep 19th, 2013 4:16 pm
Beryl Beemer Engine oil changes and filter replacements PhillWard Australia, New Zealand, and AsiaPac 1 May 28th, 2013 12:05 am
Transmission and rear drive oil... rowie K1200LT 2 Aug 18th, 2012 9:00 am
Final Drive oil color VRodPete K1200LT 10 Mar 18th, 2009 4:29 pm
