Low seat problem - BMW Luxury Touring Community
post #1 of 4 Old Jul 24th, 2014, 11:02 pm Thread Starter
cwo
cwo's Avatar
Low seat problem
I like having the low seat on my 13 GTL, but even after a custom seat rebuild I found myself moving around on the seat looking for that comfort spot. I later sat on an airhawk (which raised the seat an inch or so) and found that it was the distance to the foot pegs that was causing my problem.
Looking for advice.... should I have the new custom seat raised or the pegs lowered. Some say the pegs drag when lowered, so I am not sure what to do.
Also anything available similar to the Mick O Pegs that may be available for the GTL.
Thanks for any advice.
Chris Ogle
Life is ephemeral. Don't waste it lookin up big words.
cwo is offline
post #2 of 4 Old Jul 25th, 2014, 6:24 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Low seat problem
Lowering the pegs will cause them to drag a lot in corners. I used an AirHawk for over 25K miles till I could get the seat rebuilt & I had it raised about 1 inch. Wish I had done the seat earlier.
Stevie Shreeve
katnapinn is offline
post #3 of 4 Old Aug 3rd, 2014, 5:26 pm
Marcf's Avatar
Gents - this is a huge factor for me as well. I currently ride a GS because of the seat to peg distance. That longish distance allows my legs to stretch and take some of the pressure off my low back.
I am contemplating trading up to a K1600GTL but think I may need to have the seat built up at least 1.5 inches. Is that even possible? Would it take me so far up off the ground that I'd not be able to reach the ground? I'm 5'8" and have a 30" inseam.
Any suggestions?
Marc
2012 White R1200 GS
2006 Gray BMW R1200GS (retired)
2003 Black BMW K1200LT (retired)
Marcf is offline
post #4 of 4 Old Aug 3rd, 2014, 7:17 pm
Chris,
If you had the Airhawk up an inch, that might really be way too high. When it's inflated, it shouldn't raise you up very much or you will be sliding around on the seat. It just takes up space with a slight cushion. I think! That is how I use mine. I was sitting on my beads today and after several hours, they started to become uncomfortable. I went back to my sheepskin and then my Airhawk. If your legs hit the ground OK, my guess is that you need a seat that is raised up about an inch. I lowered my pegs with the Suburban kit, but they do drag the ground from time to time. My boots too.
tall seat need a shorter. kmb1970 K1600GT/GTL 15 Aug 15th, 2014 6:01 am
2014 Corbin Dual Seat Review. The not so good, the bad, and the ugly. evomind RT Series 5 May 28th, 2014 4:30 pm
2010 Front seat problem. dadicool59 RT Series 9 Feb 22nd, 2012 1:46 am
Ariís winter farkle projects part 4 (power seat height adjuster) pozo_izquierdo K1200LT 21 Apr 7th, 2006 11:45 am
