200/50 tire - BMW Luxury Touring Community
post #1 of 9 Old Jul 22nd, 2014, 3:54 am Thread Starter
wethead's Avatar
200/50 tire
Has anyone installed a 200 tire on a 1600?
wethead is offline
post #2 of 9 Old Jul 22nd, 2014, 6:26 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: 200/50 tire
I would be worried about the weight rating for a "50" tire. Every 190/50 I find is NOT rated for the K1600, only the "55" is weight rated for the K1600.
The extra width of the 200 may also rub on the swing arm.
Stevie Shreeve
katnapinn is offline
post #3 of 9 Old Jul 22nd, 2014, 11:44 am
Re: 200/50 tire
I'm running a 205/50-17 car tire on my GTL. I measured it as 3/4" wider than the factory 190/55-17 rear tire when mounted, so I made a 3/8" shim to avoid clearance issues with the swingarm. That required the use of longer lug bolts, which were really difficult to find.
You'd have to fit the tire onto the K16's rim and see how wide it actually sits, but there's not a whole lot of clearance there to play with.
And, as Steve pointed out, do check the weight rating of the new tire . . .
post #4 of 9 Old Jul 22nd, 2014, 11:46 am
Re: 200/50 tire
I'm pretty sure Meese has. As I understand it you need a spacer plate and longer lug bolts to give yourself clearance from the sidearm.
roame is offline
post #5 of 9 Old Jul 22nd, 2014, 11:47 am
Re: 200/50 tire
Wow. I figured you were out riding or I would have seen a post already.
roame is offline
post #6 of 9 Old Jul 22nd, 2014, 12:49 pm
Re: 200/50 tire
post #7 of 9 Old Jul 22nd, 2014, 1:01 pm Thread Starter
wethead's Avatar
Re: 200/50 tire
Well, there goes that idea then. I dont think Ibwant tonuse spacers and longer bolts in there
wethead is offline
post #8 of 9 Old Jul 23rd, 2014, 2:01 pm
Re: 200/50 tire
Well, there goes that idea then. I dont think I want to use spacers and longer bolts in there
BMW engineers these bikes with pretty tight tolerances, especially around the tires.
Honestly, there's little practical benefit to changing tire sizes, and if you go too far out you throw off the wheel speed sensors which messes with your ABS, cruise, traction control, and a whole host of other systems that use the wheel speed for internal calculations.
For most riders, it's just not worth it at all . . .
post #9 of 9 Old Jul 23rd, 2014, 2:18 pm Thread Starter
wethead's Avatar
Re: 200/50 tire
I can see your point, thanks
wethead is offline
Me 880 rear tire clayton Tires 23 Aug 29th, 2014 9:58 pm
Two Up Tire Pressure? gphusky1 RT Series 43 Sep 20th, 2013 8:55 am
Internet Automotive Tire Sales saddleman Chit Chat 8 Jan 29th, 2012 7:57 pm
Tire Changing Debacle... gulfxray Bike Talk 17 Mar 1st, 2007 3:17 pm
