Clutch Slave Cylinder Rebuild - BMW Luxury Touring Community
LinkBack Thread Tools
Old May 20th, 2014, 8:54 pm Thread Starter
gunny's Avatar
Mine leaked and ruined the clutch disk a couple of months ago.
Today, got bored and took the old, leaky one apart. Seal looked good, bore is fine. Would think a new seal (cup) would make it as good as new. The seal looks like the same design as you would find in a wheel brake cylinder.
Anyone try this? Pains me to see BMW ask and get $155 for a part that probably cost less than $10 to make. Looked real close and it appears to be made out of aluminum, not gold or platinum. Think that seal would probably sell for $3.00 or so. No precious metal found there either.
B D R
gunny is offline
Old May 20th, 2014, 8:57 pm
Re: Clutch Slave Cylinder Rebuild
The hard part is finding the seal as it is most likely a custom size knowing BMW. I think our old friend David Shealey looked into this some years ago.
Old May 20th, 2014, 10:27 pm
Several years ago I sent it to a friend who designs hydraulic systems and he sourced them for me out of a different material than the BMW original. I rebuilt several slave cylinders and to my knowledge none have failed.
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
Old May 21st, 2014, 6:52 am
johnT's Avatar
Care to share a part # ?
johnT is offline
Old May 21st, 2014, 6:59 am
Hi,
I did the same down under. Went to a local Seal manufaturer and had it built/cut. It has been going now for 2 years without an issue. Cost of initial seal Aus$75. Any new ones around $40.
I then just repacked the bearing and hope to get some good life.
Brian
bfree is offline
Old May 21st, 2014, 8:34 am
VoIPwizard's Avatar
The guys at the Chromeheads website researched for seals and found a provider. The engines are R class over there but the idea is the same.
Link to the thread here: http://www.chromeheads.org/discus/me...tml?1378530505
If the bearing is bad... you need to get a new unit.
2009 R1200RT
Past Rides: 2003 K1200LT "Gertrude" (sold) / 2004 R1200CLC "Petunia" (sold) 2005 Kawi Concours (gone)
VoIPwizard is offline
Old May 21st, 2014, 10:40 pm
Dayton Seal & Packing
110 East Third St
Dayton, Oh 45402
937 228 2300
P/N UNP-14 x 20 x 4
14mm bore.
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
Old May 22nd, 2014, 7:25 am
johnT's Avatar
110 East Third St
Dayton, Oh 45402
937 228 2300
P/N UNP-14 x 20 x 4
14mm bore.
Thanks.
johnT is offline
Old May 22nd, 2014, 6:43 pm
110 East Third St
Dayton, Oh 45402
937 228 2300
P/N UNP-14 x 20 x 4
14mm bore.
The size is correct as I just looked at my old one, but the bore is 20 mm not 14 mm.
Looks like the one the R bike guys use is a different size slave unit. Yup they use a 24 mm slave so don't order those.
Investigating the clutch slave cylinder failures K100Dennis K1200LT 2 Apr 19th, 2012 6:17 pm
How To Replace Clutch Slave Cylinder southern_nj K1200LT 13 Feb 4th, 2012 9:24 am
Back on an LT after 3 years - clutch slave cyl question Bueller K1200LT 5 May 24th, 2009 8:58 pm
Slave Cylinder Replacement - Important Lesson Learned! Schweintechnik K1200LT 0 Nov 18th, 2007 1:24 am
Anyone ever rebuild a slave cylinder? kevincook K1200LT 16 Sep 18th, 2006 10:28 am
