FD bearing replacement. - BMW Luxury Touring Community
post #1 of 8 Old May 20th, 2014, 5:31 pm Thread Starter
deanwoolsey's Avatar
Just wondering from those who have done a few FDs what the average shim thickness is on the FD. I know this one was too tight and didn't have access to replacement shims but it lasted 66,000 miles the first time so not too concerned. Was shimmed at .030 MM.
deanwoolsey is offline
post #2 of 8 Old May 20th, 2014, 5:58 pm
Enjoy The Ride
saddleman's Avatar
Re: FD bearing replacement.
I have done 43 FD's so far and the shims vary a lot in thickness.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #3 of 8 Old May 20th, 2014, 6:16 pm Thread Starter
Thanks Dave. BTW the gussets(?) made it. Nicely done. Now off to the welder.
post #4 of 8 Old May 20th, 2014, 9:21 pm
fpmlt's Avatar
I think your numbers are close to what I ended up with. Mine was over shimmed by almost double the required amount.
fpmlt is offline
post #5 of 8 Old May 20th, 2014, 11:03 pm
FatStrat's Avatar
I just did mine last weekend. From the factory, there were three shims installed. Two .20mm and one .15mm. Using the dial gauge method only one .20mm shim was necessary. That's .35mm over preloaded. That's pretty poor quality control on BMW's part. Plus...the taper bearing was spinning on the spindle which ate away .15mm of the backlash shim.
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
post #6 of 8 Old May 21st, 2014, 9:02 pm
Originally Posted by FatStrat View Post
That's .35mm over preloaded. Plus...the taper bearing was spinning on the spindle which ate away .15mm of the backlash shim.
That meas it self adjusted to only .20 mm of overload
post #7 of 8 Old May 21st, 2014, 9:14 pm
johnT's Avatar
been a couple years now... don't remember exactly... but I ended up not using one small shim... it was a .010 or .015
johnT is offline
post #8 of 8 Old May 23rd, 2014, 6:50 am
FatStrat's Avatar
Dang.....I should have waited....it was repairing itself! If the taper bearing would have welded itself to the spindle.....
FatStrat is offline
Unigo Trailer Bearing Replacement dfinazzo K1200LT 9 Jun 14th, 2015 6:01 pm
What are the suspected reasons for final drive failures av8trto K1200LT 49 May 31st, 2012 8:02 pm
No lube in final drive from factory!!! DrSuess K1200LT 17 Apr 19th, 2012 6:02 pm
Post rear bearing replacement wheel shift Stanyo K1200LT 2 Jul 18th, 2006 11:31 pm
Crown Bearing Replacement Complete scott122262 K1200LT 2 Mar 1st, 2006 7:54 pm
