That 12,001 mile maintenance feeling - BMW Luxury Touring Community
post #1 of 3 Old May 11th, 2014, 4:12 pm Thread Starter
I'm about 80% done (still have to put the big tupperwear back on, buy a 14mm wrench, change the tranny and final drive oil...make that 60% done. ) Oil, plugs, fuel and air filters, coolant, pulled the radiators and flushed them. Valve lash, while still at the ragged edge of tolerance in three places, hasn't drifted in 12,000 miles.
That oil change STILL strikes me as the most singularly sloppy oilchange in all the vehicles I've ever done (and I've done a lot.)
Still...probably won't have to do it again this year, so it's all good.
05 LT - Blue
03 VTX 1300s - fun while it lasted, sucked in the cold.
Rocketsled is offline
post #2 of 3 Old May 11th, 2014, 9:21 pm
hallzee's Avatar
Re: That 12,001 mile maintenance feeling
Oh.... You'll be singing the praises of fine German Engineering when you are working on getting the tranny oil changed!
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #3 of 3 Old May 11th, 2014, 9:40 pm
Zeke's Avatar
Great job so far. Yea the tranny can be an issue. there is a trick I learned on this site to make it a little less messy.
Take an oil bottle, cut in half length wise, without cutting the neck off, this will slide between the centerstand and empty the oil], hopefully, to your drain pan. Or you can make that goofy rubber thing that BMW shows in the book. I have done this alot, and usually works ok, 75%, but you will get it. The hardest part is getting the drain plug out at the same time, with your fingers in the way. as you said once a year isnt all that bad.
Hope that helps a little.
zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
Maintenance Schedules of My RT vs My Chevy Norms_427 RT Series 33 Jul 16th, 2012 9:02 am
6000 mile maintenance mcollect RT Series 4 May 7th, 2012 11:36 pm
12K Mile Maintenance Thoughts and Direction sgroover K1200LT 8 May 25th, 2011 10:38 am
Final Drive no longer maintenance free for 2007+ models with new style rear drive eljeffe K1200/1300GT (The Next Generation) 4 Sep 7th, 2006 2:41 pm
24000 mile scheduled Maintenance, is it really necessary ? ltlfeat K1200LT 6 Jul 29th, 2006 3:10 pm
