Pre-load adjuster on Wilbers - BMW Luxury Touring Community
post #1 of 13 Old May 11th, 2014, 11:35 am Thread Starter
cealbrecht's Avatar
I have determined that my shocks are completely blown and I'm about to order a new set of Wilbers from Ted Porter's Beemer shop online. Do I need to order the pre-load adjuster for the Wilbers rear shock or can I use the one that came with the stock one. It's an additional $250 which seems a little excessive for the purpose it serves. Has anyone tried this?
If not, then I'm wondering how well the new pre-load adjuster mounts to the bracket for the original pre-load adjuster under the seat....
Chad Albrecht
2002 Chartreuse Yellow and Black BMW K1200LT Tickets
cealbrecht is offline
post #2 of 13 Old May 11th, 2014, 1:41 pm
fpmlt's Avatar
Re: Pre-load adjuster on Wilbers
Can't really offer any advise as to what you should do, but I can tell you that the Wilbers pre-load adjuster fits fine under the seat, and that I have never touched mine. I gave Ted all the information I could about how I ride, what I wanted, etc. He set it up, and I have yet to change it in 3 years.
fpmlt is offline
post #3 of 13 Old May 11th, 2014, 10:34 pm
Pretty sure you'll need the Wilbers one... there's an additional adjustment cannister (compression reservoir, I think?) that it's attached to.. haven't touched the can since I first set it up... but I use the preloader knob same as the old one.. it fits in the same spot.
Might be a couple of different options available for setup... check your dealer.. Pirates Lair lists 4 x different setup options
post #4 of 13 Old May 12th, 2014, 6:48 am Thread Starter
cealbrecht's Avatar
I think you have the model that allows you to re-adjust the piston response for off-roading/out-backing? I believe those two screws set the extension and retraction response of the piston by controlling the valve orifices. Someone correct me, if they think I'm wrong. I don't plan to buy anything that complicated as I plan to keep my bike on the streets and highways. Thanks for the picture, that gives me a great look at the setup.
Chad Albrecht
post #5 of 13 Old May 12th, 2014, 6:53 am Thread Starter
cealbrecht's Avatar
So, you haven't found the need to re-set the pre-load adjustment? Do you always ride 1 up? Or always ride with your SO? I know there is a questionnaire that asks about the percentage of time spent with a passenger and the additional weight. If everything has been fine for 3 years without adjustment, while switching between loads, then I may go without the adjuster... I'm sure I could always add one on later for $200-300, if needed.
Chad Albrecht
post #6 of 13 Old May 12th, 2014, 7:35 am
K100Dennis's Avatar
The 2 screws on the cannister adjust the low and high speed compression damping rates. Rebound damping is adjusted by the wheel on the shock unit itself. Preload on the spring is necessary if you intend to buy a Wilbers shock, as you will be asked for your weight, the percentage time you operate 2-up, with/without luggage and riding style. When the shock unit is built the spring will be rated such that no preload is required for single rider operation unloaded, from there the preload is used progressively. Fully laden my bike goes just on the allowable 600 Kg and the preload is set at 8 full turns of a possible 12. Bike feels perfect in every situation and never bottoms out, I can't recommend the Wilbers highly enough, money well spent.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #7 of 13 Old May 12th, 2014, 12:39 pm
fpmlt's Avatar
I alternate between riding one up empty and loaded, and two up loaded. I like the ride a bit stiff empty, for handling, so having it set for two up works fine when I'm solo. Probably a personal thing, so you'll need to take my set up with a grain of salt.
fpmlt is offline
post #8 of 13 Old May 12th, 2014, 7:16 pm
+1 on a stiffer ride for improved handling stability, also my preference.
Dennis.. thanks for the more comprehensive explanation... my brain just said "oh yeah, that can thing... what was that for?"... lol
Only problem with the compression reservoir location is I need to twist it out of the way any time I want to get the diagnostic cable out for the GS911.
post #9 of 13 Old May 12th, 2014, 10:24 pm Thread Starter
cealbrecht's Avatar
Thanks everyone for the great information as always. I think that I will place the order tomorrow, but I think that I'll call Ted directly and see what he has to say about the adjuster. I'll let you know if he says that I can simply use the OEM....but I seriously doubt that that will be the answer. I get the feeling that I'll fork over the extra loot.
Chad Albrecht
post #10 of 13 Old May 13th, 2014, 8:32 pm Thread Starter
cealbrecht's Avatar
In the end, I purchased the front and rear shock pair with the Wilbers pre-load adjuster installed. It turns out that the pre-load adjuster is an additional hydrolic piston assembly that is installed onto the standard shock and spring assembly. I was originally thinking that the shock was built standard with this assembly already attached. This is the justification for the extra $250. If you don't pay for it, then the shock will come to you bare with only a spring and piston. I did not question whether the OEM pre-loader can be fitted onto the Wilbers.....it's not something I would have wanted to tackle anyway. It might have jeopardized the integrity of the factory setup of my new shocks.
Chad Albrecht
post #11 of 13 Old May 31st, 2014, 11:43 pm Thread Starter
cealbrecht's Avatar
I received my new Wilbers yesterday. Installed them today. I had to use a hammer to persuade the front shock over the little metal lip near the bottom side. Is there a special trick to it.....I was able to install the shocks, but I would like to know if there is a better way to maneuver the front shock into place.
BTW, the new shocks are awesome. Went for a 1 hour test ride and found that the tracking through some hard cornering is much more predictable and accurate.
Chad Albrecht
post #12 of 13 Old Jun 1st, 2014, 4:57 am
Enjoy The Ride
saddleman's Avatar
I have had to file a little off of the front lower shock many times so it fits easily.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #13 of 13 Old Jun 1st, 2014, 6:45 am Thread Starter
cealbrecht's Avatar
Thanks Dave, it's good to know that even some of our more mechanically inclined members were having the same problem.
I ultimately needed to remove the metal sleeve that goes over the upper screw and then I found a big washer and used it under the upper nut to draw the shock up as high as I could by compressing the rubber gaskets as much as possible. I still found it necessary to employ a hammer to nudge the lower side of the shock over the front of that 'catch lip'. Once it was in place, I removed the upper nut and washer, re-installed the metal sleeve by pushing it down through the top hole and wiggling it until it seated into the rubber gasket on the top of the shock, and then I put the upper gasket on and tightened everything up with the top nut.
Chad Albrecht
Re-filled Preload Adjuster on Rear Shock JPSpen K1200LT 48 Jul 26th, 2017 1:56 am
Heated seat vertical adjuster question JnKDad K1200LT 9 Jan 22nd, 2013 6:34 am
Help Needed with Ohlin pre load adjuster mos K1200LT 8 Feb 18th, 2008 5:22 pm
wilbers USA done? tmgs K1200LT 27 Apr 22nd, 2007 11:45 pm
Suspension.....(again!!!....sigh) PhillWard Australia, New Zealand, and AsiaPac 26 Nov 13th, 2006 11:38 pm
