Has anyone tested an alternator? - BMW Luxury Touring Community
post #1 of 8 Old May 7th, 2014, 5:27 pm Thread Starter
GBarnes's Avatar
My '06, with 91,000 miles, hasn't seemed to be charging as well as it used to. I've done all of the normal tests: it puts out 13.6 volts at 2500 rpm. However, since I have the bike apart for a rear main seal job, I figured I would have the alternator tested, and maybe rebuilt, by an auto electric shop. I'm having trouble finding anyone who will do it since it doesn't have a pulley like it would on a car. I guess I can find a pulley at a junk yard and mount it on the alternator, but that seems like a pain in the neck.
Has anyone here ever had an alternator professionally tested?
TIA
George Barnes
'06 K1200LT
'01 K1200LT, totaled with 180,000 miles, 10/18/07,
'97, '99, '01, '05, '07 & '09 Iron Butt Rallies, (won the '99)
IBA#146
GBarnes is offline
post #2 of 8 Old May 7th, 2014, 6:06 pm
deanwoolsey's Avatar
Re: Has anyone tested an alternator?
I would check/replace the bearings, throw a set of new brushes on it and call it good.
deanwoolsey is offline
post #3 of 8 Old May 7th, 2014, 6:15 pm Thread Starter
GBarnes's Avatar
Talking Re: Has anyone tested an alternator?
Dean,
The video here: https://www.youtube.com/watch?v=bTcMD5_EznI
explains how to replace the brushes. It seems like a lot of work if the alternator is OK. On the other hand, after the rear main seal job, what's another hour or so, right?
George Barnes
'06 K1200LT
IBA#146
GBarnes is offline
post #4 of 8 Old May 7th, 2014, 6:24 pm
Enjoy The Ride
saddleman's Avatar
When I replaced my clutch at 180,000 miles I replaced my alternator & starter with rebuilds I had done at a local re-builder. I had spares that I had rebuilt a few years ago. Phil's Alternator & Starter in Cherryville NC rebuilt mine. Phil is factory trained at Bosch in Germany for his rebuilds. My rebuilt starter cranks the engine much faster than the OEM starter did.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #5 of 8 Old May 7th, 2014, 9:52 pm
13.6 at 2500 RPM is more than enough to properly charge the battery since the battery open circuit voltage is 12.7 tops. Current will go into the battery. But really the job of the alternator is to provide power to the electrical loads and anything left over is for charging the battery. So unless the thing puts out less than 12.7 volts it is working correctly.
post #6 of 8 Old May 7th, 2014, 9:55 pm
At higher RPM the normal charge voltage is 13.4 volts +/- 0.3 volts.
post #7 of 8 Old May 7th, 2014, 10:05 pm
One problem with the LT alternator is that one slip ring on the rotor wears much faster than the other one. If I remember it is the inner one that wears first.
The slip ring assembly can be replaced. Best done by an alternator shop.
http://europartshouse.com/index.php?...roducts_id=123
post #8 of 8 Old May 8th, 2014, 11:45 am Thread Starter
GBarnes's Avatar
Originally Posted by dshealey View Post
...The slip ring assembly can be replaced. Best done by an alternator shop.
My thoughts exactly. I saw your post about this a while back and it seemed like a good idea.
GB
George Barnes
'06 K1200LT
IBA#146
GBarnes is offline
Replacing alternator belt Marve RT Series 21 Apr 30th, 2014 9:40 am
junk battery or bad alternator? or both? johnT K1200LT 21 Aug 4th, 2011 12:37 pm
Help with Autocom alternator noise cliffy109 Intercom, CB, & 2-Way Radios 2 Apr 14th, 2010 2:42 pm
Alternator Noise Suppression Dragonfire Batteries, Chargers, & Electrical 2 Jul 13th, 2006 12:07 pm
My Ninja's got a new 45-amp alternator...seeking advice messenger13 Chit Chat 11 Feb 14th, 2006 7:18 pm
