Un-trusting mirrors - BMW Luxury Touring Community
post #1 of 3 Old May 6th, 2014, 12:43 am Thread Starter
Un-trusting mirrors
Looking to see if there is any way to tighten my mirrors? It's bad enough that I have to use a spot mirror for the huge blind spot then add in the mirror want stay set makes for some interesting moments. :dance
big C is offline
post #2 of 3 Old May 6th, 2014, 4:24 am
Axle's Avatar
Re: Un-trusting mirrors
remove mirrors check to see if any of the housing is broken around the clips, if not check behind the little nipple bolts some times there is a washer behind them which you can remove that's about it.
put a little bit of grease on the ball to help the clip slide over
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 3 Old May 6th, 2014, 7:42 pm
Replace the mirror adjuster in back of mirror.
There $22.50 each from max bmw.
Just replaced mine installed muth led signal mirrors there are nice.
XIILT is offline
Muth mirrors report skurtenbach K1200LT 20 Oct 17th, 2013 10:40 am
2nd set of mirrors on handlebars ahpd1992 K1200LT 31 Jul 25th, 2013 10:53 pm
Agding GS Mirrors to the R1200RT twkBMW RT Series 17 Mar 16th, 2013 11:23 am
Adding Mirrors to a R1150RTP jireynolds67 RT Series 4 Apr 26th, 2011 9:52 pm
stock mirrors cwo K1200LT 5 Nov 5th, 2010 7:52 pm
