Re: 05 leak between engine and clutch housing
If it is leaking between angine and trany you will find drops of oil on the floor when parked overnight. the drops will come from inside the bell housing at the bottom of the bell housing, on the left if you use the side stand.
If you aren't sure where the few drops come from you can drill a small hole into the bell housing at the lowest point for whichever stand you use. with the small hole you should be able to verify if inside the bell housing has oil in it.
mine leaked for a few years before the clutch started slipping in 5th. The PITA is that my cruse controll kicks out in 5th on interstates.
bob
