Another clutch question. - BMW Luxury Touring Community
post #1 of 5 Old May 3rd, 2014, 1:59 pm Thread Starter
k12robert's Avatar
So had clutch and leaking slave cylinder replaced last year, $1700 thank you very much, at my local BMW dealership. On the way to work this week noticed clutch lever getting spongy and fluid level is down to the bottom of the window on master cylinder. Could this be slave cylinder leaking again? I can see no sign of fluid anywhere, where in particular should I check? Should I even ride it if fluid contaminates the plate.
If this means another expensive rebuild I am going to be another ex LT owner, plus V pissed off at westside motorsports.
Robert
k12robert is offline
post #2 of 5 Old May 3rd, 2014, 2:35 pm
Re: Another clutch question.
Robert
Sounds like a leak. I was thinking that repairs done by a dealer had a 24 month warranty. I would call your dealer and inquire.
post #3 of 5 Old May 3rd, 2014, 7:00 pm
If the level changes normally then it will go up, not down so yes you have a leak. Could be slave could be hose, best to get it checked.
post #4 of 5 Old May 3rd, 2014, 8:17 pm
MartyBlok's Avatar
I had issues with my new slave after dealer repaired. It went back in and they put a new slave on with a couple of other seals that they said were leaking. They fixed it on their dollar. Take it back.
Marty Blok
99 LT
MartyBlok is offline
post #5 of 5 Old May 3rd, 2014, 9:00 pm
gunny's Avatar
That does not sound good. If I were in your shoes, I would haul it to the dealer, not ride it in the hope that the clutch disc is not yet contaminated.
Did they drill a weep hole? If so, that probably saved the disc and makes a repair a relatively simple job compared to replacing the disc. If not, have them drill the weep hole when they are in there.
Give them the opportunity to make it right.
B D R
gunny is offline
Clutch master cyl. question jbwbhs K1200LT 3 Jun 15th, 2013 5:41 pm
I fought the clutch and the clutch won. Slammer Chit Chat 3 Apr 15th, 2013 12:56 am
05 r1200gs Clutch fluid question? byke33 GS Series 2 Apr 3rd, 2010 6:29 pm
question on clutch resevior byke33 GS Series 1 Aug 22nd, 2007 12:08 pm
Clutch Repair Question 02lt K1200LT 2 Jun 6th, 2006 12:24 pm
