Curious ABS symptom after flushing? - BMW Luxury Touring Community
post #1 of 6 Old May 3rd, 2014, 12:34 am Thread Starter
Guest
11862's Avatar
I flushed and bled my 2005 K1200LT using the Integral brake procedure. When finished, I have a nice hard pedal and handbrake lever, but only when the pump is on.
But with the switch off, the front brake handle seems noticeably softer, the rear pedal not so much softer. Unfortunately I never checked the brake stiffness before starting out.
Does anyone have an LT like mine with a soft hand lever when there is no electrical power to the ABS?
11862 is offline
post #2 of 6 Old May 3rd, 2014, 12:38 am
deanwoolsey's Avatar
Re: Curious ABS symptom after flushing?
If that is a power assist ABS where you hear servos run when you apply the brakes, the soft lever/pedal is normal with the ignition off.
deanwoolsey is offline
post #3 of 6 Old May 3rd, 2014, 6:46 am
You should notice a different feel and clicking down in the ABS unit as you pull as hard as you can. But it should stop at a point and not feel mushy.
post #4 of 6 Old May 3rd, 2014, 8:41 am Thread Starter
Guest
11862's Avatar
Wow! The two National BMW experts! (Do you guys ever sleep?)
Yes, it is the power assist version where the pump runs whenever either brake is engaged. I somehow have never noticed the hand lever difference switch-on vs switch-off. Must be why the procedure suggested a qualitative feel check before breaking into the system.
I still have plenty of DOT 4 and easy setup to bleed the calipers some more FWIW.
Thanks guys!
11862 is offline
post #5 of 6 Old May 3rd, 2014, 11:16 am
SilverBuffalo's Avatar
Just checking, did you bleed all four,
from handle bar to pump and then (key on) from pump to calipers
also rear reservoir to pump and then (key on) pump to rear caliper
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #6 of 6 Old May 3rd, 2014, 5:07 pm Thread Starter
Guest
11862's Avatar
Lets define the farthest-in tap as #1, and closest tap to LHside as number 6. Then the tall taps are numbers 2 and 5.
I bled the three front control circuit taps first #1, then #4, then #2, then back to #1
for a second burp.
Likewise I bled three taps for the rear control circuit starting with #6 (closest to LH side), then #3, then the tall one at number five which again is the closest tall one to the LH side, then returned for final burp at #6 the closest one. Does this make sense?
I have a home brew rig which feeds both power circuits simultaneously. It is still connected.
11862 is offline
Flushing Integral ABS Brakes Jim_McG K1200LT 25 Mar 19th, 2014 2:49 pm
Where is the post/thread on flushing the brake fluid & ABS unit on 2000 LT wildwestrider K1200LT 7 Apr 17th, 2008 9:30 pm
ABS Flushing and Bleeding 101 JeffB K1200LT 11 Feb 13th, 2006 1:27 pm
