Replacing rear main seal - BMW Luxury Touring Community
LinkBack Thread Tools
Old Apr 29th, 2014, 2:21 pm Thread Starter
I am doing a clutch job on my 2000 LT. While in there I want to have a look at the rear main seal. In watching Kirk's video he uses a tool the lock plate into place while he crack the jack nut. It looks like a flat metal bar with holes at either end to bolt it onto the housing. Is it a simple as that. If so I assume I can make one.
Help is appreciated.
Jimmymac is offline
Old Apr 29th, 2014, 2:32 pm
sailor's Avatar
Re: Replacing rear main seal
The CLYMER manual has an example of what this looks like. No real complicated measurements that you cannot take yourself with simple tools.
Look at 2 attached picture for 2 examples made by 2 different persons...
ID:	54633   Click image for larger version
John (Montreal, CANADA)
sailor is offline
Old Apr 29th, 2014, 3:34 pm
fpmlt's Avatar
I made mine out of flat stock I had laying around.
fpmlt is offline
Old Apr 29th, 2014, 6:02 pm Thread Starter
Thanks guys, think I'll make my own.
Cheers
Jimmymac is offline
Old Apr 29th, 2014, 6:05 pm
gunny's Avatar
Yes. Made out of flat bar stock.
If not leaking or showing evidence of leakage, I'd consider leaving it alone.
Just did the clutch on my '03, the clutch failed because of the slave cylinder. Replace (2) parts, the clutch disk and the slave cylinder. Rear main looked Ok as did the transmission seal so left both of them alone. See where they typically last well over 100K.
B D R
gunny is offline
Old Apr 29th, 2014, 6:49 pm
When you do remove the clutch housing you will have to dig out a hardened 19 x 4 o-ring on the shaft that was most likely the cause of the leak. Best to replace it with a Viton o-ring from the "o-ringstore.com".
Old Apr 29th, 2014, 6:50 pm
fpmlt's Avatar
I changed ALL my seals while it was apart. If you choose to leave the main seal alone, at least change the O-ring.
fpmlt is offline
Old Apr 29th, 2014, 6:52 pm
Scouter-50's Avatar
Go here: http://www.bmwlt.com/forums/showthre...=special+tools
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
Old Apr 30th, 2014, 6:44 am Thread Starter
Wow I have watched John's videos but did not know about the web pages with plans and dimensions for the very tools I need.
Thanks for the info it will make it doable for me.
Cheers
Jim
Jimmymac is offline
Thought it was the rear seal but what's this... sumber101 K1200LT 26 Mar 5th, 2014 12:26 am
Rear Seal and others issues hd2bmw K1200LT 16 Jan 24th, 2011 1:26 pm
replacing rear rotor - 01 LT lkniess K1200LT 5 Oct 28th, 2010 6:46 pm
Main seal or slave cyl....apples or oranges?? btruex373 K1200LT 7 Jun 25th, 2008 4:29 pm
Rear Engine Seal Replacement...Help sgt K1200LT 9 Sep 3rd, 2007 9:54 am
