Buckets - BMW Luxury Touring Community
post #1 of 20 Old Apr 26th, 2014, 10:20 pm Thread Starter
rattler50's Avatar
Question Buckets
I'm about to run my valves and I'd like to know where I might purchase the buckets I might need. I'm sure I'll need a couple....................
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #2 of 20 Old Apr 26th, 2014, 11:19 pm
azccj's Avatar
Re: Buckets
Well the buckets will cost you $21.90 each if you get them from the dealer. There are 15 different sizes, so you could buy all 15 for $328.50 but even then you might not have enough of 1 size to adjust all that are out of spec. Best to measure all the valve clearances, keep good notes and then buy what size bucket you need or ask the members here if they have what you need. The odds that your local dealer will have the size you need sitting on a shelf are slim to none. So if you need to replace any buckets it will be at least a few days before you could have the bike running again.
I really do like screw adjusters. Ya, they need to be checked more often but you can do the job quickly not needing to wait for shims or in this case buckets to come from the dealer. On my Moto Guzzi Norge which has a full fairing, the valves can be adjusted in just 20 minutes and not a single piece of bodywork needs to come off to do it.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #3 of 20 Old Apr 27th, 2014, 9:22 am
Re: Buckets
Bad news is cars with over head cams are using solid buckets as well
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is online now
post #4 of 20 Old Apr 27th, 2014, 10:04 am
Re: Buckets
Wow I remember when they were $12.00. But I have never purchased one. Many of us have a "bucket bank" and will gladly send off what you need if we have it. So once you figure out what you need, put it in a post here.
post #5 of 20 Old Apr 27th, 2014, 2:10 pm Thread Starter
rattler50's Avatar
Re: Buckets
Well, I got my front shock installed this morning and I tore into the engine to check the valve clearance. All the valves are in specs except for the two intake valves on #1 cylinder. They are reading .005 on both. That's just .001 too tight. Does that warrant further teardown to change those two buckets?
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #6 of 20 Old Apr 27th, 2014, 2:27 pm
Re: Buckets
I changed mine that were on the tight limit or below it. I can't say you have to, but I would. Burning the valves and/or seats can be expensive. And on the LT, most of the work is getting to the valves. Pulling the cams isn't that much more work. The only part I found tricky was getting the pin in to hold the tensioner. I didn't get it right at first and knew instantly when I removed the first drive gear and had the chain pull it into the housing.
Fortunately, a week later I was able to easily press the chain guide down with a large screwdriver and install the pin correctly. Assembly was quite easy then. I approached the job with so e trepidation the first time, it my concerns were largely unfounded. Will be much easier next time around.
post #7 of 20 Old Apr 27th, 2014, 5:06 pm Thread Starter
rattler50's Avatar
Re: Buckets
The buckets I pulled are .00280 so I should need two .00275 buckets. That will make it a little loose. Right?...........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #8 of 20 Old Apr 27th, 2014, 6:09 pm Thread Starter
rattler50's Avatar
Exclamation .00275 Buckets
I am in need of 2 if anyone has any..............
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #9 of 20 Old Apr 27th, 2014, 7:56 pm
DanMartin's Avatar
Re: Buckets
Nope, puts it right in the middle at .007. 2.70 would put you at .009
DanMartin is offline
post #10 of 20 Old Apr 27th, 2014, 8:55 pm Thread Starter
rattler50's Avatar
Re: Buckets
Doh! I was measuring in mm and thinking in thousandths......
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #11 of 20 Old Apr 27th, 2014, 9:49 pm
Re: .00275 Buckets
If you mean 2.75 mm I have two.
post #12 of 20 Old Apr 27th, 2014, 9:53 pm Thread Starter
rattler50's Avatar
Re: .00275 Buckets
Great........just let me know how much and I'll PayPal you if that's okay........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #13 of 20 Old Apr 27th, 2014, 10:03 pm
Re: .00275 Buckets
I'll stick them in a padded envelope and mail them tomorrow. When you get them just send me your old ones to go into the pool and throw in a few bucks for postage.
post #14 of 20 Old Apr 27th, 2014, 10:08 pm Thread Starter
rattler50's Avatar
Re: .00275 Buckets
Will do..........thanks.
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #15 of 20 Old Apr 28th, 2014, 3:39 pm
Re: Buckets
On their way. Should have them Thursday (if the Tornadoes don't get 'em).
post #16 of 20 Old Apr 28th, 2014, 11:16 pm
Tobster's Avatar
Re: Buckets
Not to take away from the thread, but how did you guys manage with the storm? I was in our EOC today and noticed some rough stuff passing over your way. I hope all is well.
Toby
03 K1200LT
Tobster is offline
post #17 of 20 Old Apr 29th, 2014, 9:06 am
Re: Buckets
Bow echo was close, just to the north. Lots of trees down in the neighborhood but no damage here.
post #18 of 20 Old May 1st, 2014, 8:26 am Thread Starter
rattler50's Avatar
Re: Buckets
Got my buckets in the mail yesterday. I'll be putting the bike back together today. Might as well do the cannisterectomy while I'm there.........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #19 of 20 Old May 2nd, 2014, 1:48 pm
Re: Buckets
Are the buckets factory installed all the same thickness? Or do I need to pull the cam shaft to determine what each bucket is?
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #20 of 20 Old May 2nd, 2014, 3:07 pm Thread Starter
rattler50's Avatar
Re: Buckets
The buckets are different sizes. You have to pull the cam and take the bucket out and look at the stamp on the inside...........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
Need Buckets, Have Buckets to Trade oldfast1 K1200LT 29 Apr 25th, 2013 10:55 am
Pulling Cam's to Mearsure Buckets saddleman K1200LT 7 Oct 5th, 2010 5:55 pm
When to Change Valve Buckets tonyn1 K1200LT 10 Jul 1st, 2009 7:47 pm
Old Valve Buckets... bigbear K1200LT 13 Oct 5th, 2007 12:15 pm
Buckets c00k1e K1200LT 5 Mar 26th, 2007 9:47 pm
